997TT - Tire size help (19x9 front & 19x12 rear) biggest size i can run?
Old May 17, 2019 | 09:54 AM
supra.z06's Avatar
supra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant future
997TT - Tire size help (19x9 front & 19x12 rear)whats the biggest size i can run?
19x9 fronts with 53et
19x12 rears with 44et
Old May 17, 2019 | 11:24 AM
GT3 Chuck's Avatar
Administrator
To answer your question members will need to know wheel offsets
Old May 17, 2019 | 12:15 PM
@pkop2JZ's Avatar
@pkop2JZ is a name known to all@pkop2JZ is a name known to all@pkop2JZ is a name known to all@pkop2JZ is a name known to all@pkop2JZ is a name known to all@pkop2JZ is a name known to all
Offset makes a huge difference, but here are some possible combos, the wider the rubber, the higher the offset needed.
245/35/19 or 255/35/19 with a 325/30/19
265/35/19 with 345/30/19 if you are brave enough!
Old May 17, 2019 | 12:42 PM
turb0's Avatar
turb0 is infamous around these parts
What wheels are you using, stock 997.1TT wheels?
Old May 18, 2019 | 01:16 AM
monsoonhell's Avatar
monsoonhell is infamous around these parts
I run those rims you mention in your post both in 19s and 20s. If running 9s in the front and having 245/35s on them.. I can tell you that when turning all the way to the right, the tire will rub on the upper inter-cooler hose (driver's side). When I have my suspension replaced, I will replace both hoses since the access will be readily available. Your alignment in the front may not have this effect, mine is set aggressively.
Old May 22, 2019 | 09:11 PM
supra.z06's Avatar
Offsets added
Old May 23, 2019 | 08:01 AM
@pkop2JZ's Avatar
These are some CCW Classics that I helped a local customer out with, specs are:
19x9 +43 with 245/45/19
19x12 +39 with 325/30/19
Lowered on springs
No fender rolling or rubbing
Based on the offsets you provided for your wheels, I say you are good to go with a 245/325 setup!
Old May 29, 2019 | 04:10 PM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
It depends on the offset, but, I am running 245/35/19 and 325/30/19 without any issues. No rubbing under heavy turning or any issues. I am running PS4s and just switched from R888s 235/35/19 and 305/30/19.
yumaverick
Nov 3, 2014 02:14 AM
charleysung
Ferrari
Mar 21, 2012 01:41 PM
k-ore
Sep 18, 2010 10:35 PM
RWDRIFTC2
Ferrari
Oct 5, 2005 12:42 AM
