Is there any advantage to buying an 08 vs 07?
Old Apr 9, 2020 | 09:57 AM
Bookshelf's Avatar
Bookshelf is infamous around these parts
In the threads about coolant pipes and cam issues I’ve seen it mentioned that these problems affect 07’s more, is there definitive truth to that? Are there any real differences between the years with anything else? Thanks
Old Apr 9, 2020 | 02:40 PM
Dennis C's Avatar
I've read the things that you mention. I often read that the adhesive used for the coolant pipes in the 2008 and 2009 cars were improved over the 2007 cars, and therefore there are less coolant pipe failures. I have no idea if this is true or not. Aside from that, I don't know of any differences between the cars. The cabriolet was introduced in 2008, but I don't know of any other differences.
Old Apr 9, 2020 | 03:38 PM
Skwerl's Avatar
Skwerl is infamous around these partsSkwerl is infamous around these parts
The story I always hear is that cars delivered in the 2nd half of 08 will have the new-and-improved adhesive. Basically, that early 08s don't have it yet.
Old Apr 9, 2020 | 04:21 PM
Bookshelf's Avatar
I guess I would still want to weld or pin the pipes when the engine is out for something else. The cam issue is a little more worrisome. Has anyone replaced cams and had it happen again?
Old Apr 9, 2020 | 06:08 PM
maverick997's Avatar
maverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to all
I have an 07 and have had it from new.....has 39k miles now. Had the coolant pipes done under warranty in 2018 and had them put the sharkworks kit as the replacement parts. Really had no other issues with the car from the engine other than a broken coolant T pipe at the rear of the engine when it had 2k miles.
Old Apr 9, 2020 | 08:43 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
Also an updated PCM head unit on 08
Old Apr 10, 2020 | 03:56 PM
jakethunder's Avatar
jakethunder is infamous around these parts
I have a 2008. Mine still had the coolant pipe issues. I changed them out with the Sharkwerks set.
Not sure if it was early or later in the year production.
Old Apr 10, 2020 | 04:49 PM
robhamster's Avatar
robhamster has a spectacular aura aboutrobhamster has a spectacular aura about
My '07 had the coolant pipe issue at 42K miles 4 years ago. Welded em. Been rock solid on every other issue.
Old Apr 11, 2020 | 07:35 AM
cjcam930's Avatar
cjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond repute
^ Yep my '09 also had the coolant leak ~41K
Old Apr 11, 2020 | 08:09 PM
Skwerl's Avatar
That was introduced the 09 model year on Turbos. Part of the 09's special appeal.
Old Apr 27, 2020 | 09:28 PM
babypimpin's Avatar
babypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to behold
From what I understand, yes the late 2008 had an improved adhesive, but regardless of what year 997.1tt, you should pin them as a precautionary measure. Just budget that into your purchase price as it's something you should do regardless.
nguyennhatquang
Bentley
Jan 20, 2018 03:10 PM
ILikeEsses
Oct 31, 2013 08:53 AM
MK Porsche
Lamborghini
10
Jul 27, 2011 04:42 PM
boochook
Mid-Atlantic
Sep 16, 2008 02:40 PM
