Battery maintainer
Old Aug 12, 2020 | 03:15 AM
Charlie Clark's Avatar
5 Year Member
Charlie Clark is infamous around these parts
Battery maintainer
Any recommendations for a Battery maintainer for a 997.2 Turbo. Thanks!
Old Aug 12, 2020 | 04:37 AM
Sobrut911's Avatar
Sobrut911 is infamous around these parts
I have been using Battery Tender with cigarette lighter adapter for decades. It’s easy to use and inexpensive.
Old Aug 12, 2020 | 02:32 PM
matt2ace's Avatar
matt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to all
I use CTEK chargers for all 4 cars. My turbo battery (Interstate) is now 7 years old, cranking like new!
Old Aug 14, 2020 | 06:03 PM
5 Year Member
Battery maintainer
Are the cigarette lighter battery maintainers safe to use? Thanks.
Old Sep 9, 2020 | 11:49 PM
coquitlam1's Avatar
coquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of light
CTEK is the way to go
Old Sep 10, 2020 | 12:49 PM
DoDaLeCa's Avatar
DoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud of
Nico (G7200 model of mine now superseded) as always on sale at Canadian Tire every few weeks.
Old Sep 10, 2020 | 01:51 PM
coquitlam1's Avatar
if you use lithium battery, you will need the one with lithium battery
Old Sep 12, 2020 | 07:31 AM
5 Year Member
Battery maintainer
Thanks for the replys!
Old Sep 13, 2020 | 04:22 PM
Pmorritt's Avatar
Pmorritt is just really nicePmorritt is just really nicePmorritt is just really nicePmorritt is just really nice
only if you smoke.
Old Sep 13, 2020 | 07:41 PM
Dguth's Avatar
5 Year Member
Dguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of light
They are safe. Used mine for over 4 years now.
Old Jan 22, 2021 | 11:37 AM
Meshari's Avatar
Meshari is infamous around these partsMeshari is infamous around these parts
I bought the porsche OEM one, It may be from Ctek as they look quite similar, they are about $150~$200 depends on your dealer.
Old Jan 27, 2021 | 06:51 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
They make a number of versions and they work really well.
Old Feb 1, 2021 | 06:35 PM
maverick997's Avatar
maverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to all
CTEk....they make Porsche version and yes the Pcar decal costs you more😂 I’ve used them for years and they work great. The cigarette lighter isn’t always the best option as when the car goes to sleep so does the socket. I use the hard wire to the battery and just pop the plug below the cowl when driving.
Old Feb 2, 2021 | 10:19 AM
babylonboots's Avatar
babylonboots is infamous around these parts
That's been my concern as well. The cigarette lighter stops working when the car is turned off. Thus, the circuit is cut. How does the charger continue to work under this condition?
UPDATE: I got the CTEK today and plugged it into the cigarette lighter. It seems that the battery is recharging just fine. I read more and it seems that the port is active for some time... The status is 4, recharging the last 80% of the battery. I ordered the extension for the cable so I can mount the charger to the wall of my garage. I'll give it some room to dissipate the heat it puts out.
Old Feb 6, 2021 | 09:26 AM
wcarson's Avatar
wcarson has a spectacular aura aboutwcarson has a spectacular aura aboutwcarson has a spectacular aura about
I use a CTEK and use the cigarette lighter in the center console. The socket doesn’t appear to go to sleep or disconnect. After a week or more, the charger is still doing it’s thing and works fine. My car is an 07 model year.
