Hans device
Old Dec 13, 2006 | 09:11 AM
997TT HKG's Avatar
997TT HKG is infamous around these parts
Hans device
Do we need a Hans device for track day?
Old Dec 13, 2006 | 11:58 AM
Texas911's Avatar
Texas911 is infamous around these parts
For a DE, probably not.
Old Dec 13, 2006 | 12:37 PM
GT3 Chuck's Avatar
Administrator
although anything you can do to make yourself more safe in an incident is just prudent...if your question was whether you are required to have a hans device...no DE organizers that I know of require a neck restraint of any type but for racing most organizations require some form of neck restraint, with some now specifying Hans...check the specific requirements for the DE you are going to attend....
ps..I use a Hans whenever on track
Old Dec 13, 2006 | 04:20 PM
john rice's Avatar
john rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to behold
Gents, I echo the YES sentiment. I raced SCCA in the 70-80s and used to play a lot on track. I have been out of it for quite some time but when I was recently reoutfitting "the driver" I concluded it was a necessity. I had a couple of serious accidents back in the day and I feel very lucky that most everything still works. One slight hit the wrong way and you are no longer "you" again. Look at the most recent deaths on track and how well the cars survived. There was no reason for the occupants to die but cars can take impacts that our necks won't. These are very cheap insurance if you want to come home and enjoy your lives. If you are single, whatever, but if you have a family I think you owe it to them.
John Rice
Old Dec 13, 2006 | 05:04 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Ditto that.
And I might add.........sh#t happens fast at 160mph......and it happens without regard to whether that event "required" that restaint, and without regard to whether that event was 'called' a DE, an SCCA event, or a Club Race.
Old Dec 13, 2006 | 06:59 PM
GT3 Chuck's Avatar
Administrator
also keep in mind that a Hans device without properly installed seat and restraints (harness) can do more harm than good...
Old Dec 13, 2006 | 10:02 PM
Texas911's Avatar
DE is not a race.
Old Dec 13, 2006 | 10:14 PM
TT Surgeon's Avatar
No, it is not required at a DE. Might be overkill (and not work as well) with stock seats and stock seat belts. Your call.
Old Dec 14, 2006 | 12:34 AM
997TT HKG's Avatar
John Rice
I agreed but if I use stock seats and stock seat belt will it work? For use on our street cars, which Hans specs? 20degree?....will it matters on the size of the shoulders/ chest?
Old Dec 14, 2006 | 01:00 AM
GT3 Chuck's Avatar
Administrator
Hans device should not be used with stock seat and belts...there are other types of neck restraints that aren't harness dependent that would be better in that situation...read this...
http://www.speedwaremotorsports.com/...s%20Manual.pdf
Old Dec 14, 2006 | 08:28 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Alot of tech stewards and DE chairman have advised people against using harnesses and fixed-back seats without rollbar for the very notion that a rollover could lead to increased risk of head and neck injury
Old Dec 14, 2006 | 08:50 AM
zona's Avatar
zona is infamous around these partszona is infamous around these parts
VSE CHUCK is correct.
The Hans device will not work as designed using stock seat belts, unless the belts are harness belt type (both shoulders). The Hans device also has specific seat and harness mounting requirements. IMO, if you can comply with all the requirements then its a no brainer- this device can help save you from serious neck injuies if involved in a accident. The neck is a sensitive area and the sudden whiplash at any speed could cause serious injury.
-z
Old Dec 14, 2006 | 12:24 PM
Vincy's Avatar
Vincy is infamous around these parts
I can't use the Hans device.
I tried a Hans device on the track and couldn't use it. No matter how I adjusted it my head was pushed forward which I found made me too uncomfortable to drive. This was in a Vet. I think the seats must be designed for a Hans device, and I don't know how it will fit in a tt, I sent it back to Hans. I'm not reckless and believe is safety we a roll bar and Halon fire suppression. I wish I could use the Hans device.
Old Dec 14, 2006 | 12:53 PM
GT3 Chuck's Avatar
Administrator
Vincy, your problem was the seat...if the angle is too upright and there is no recess in the seat for the rear collar on the Hans it will bump your head forward...look at:
LFT Tech R3
Hutchins II
Hutchins Hybrid
Leatt Brace
Isaac
The R3 and Hutchins will work with a more upright seat...
Old Dec 14, 2006 | 01:51 PM
Josh/AWE's Avatar
Gents-
Just wanted to chime in.
We sell the R3 Device. Please take a look at our site. We have data that many of you may be interested in. This may also help what is best for you.
Click the link below.
http://www.awe-tuning.com/pages/shar...ck&IL=r3device
Please let me know if you have any further questions.
