CEL light?
Old Apr 23, 2007 | 02:02 AM
lamvince's Avatar
lamvince is infamous around these partslamvince is infamous around these parts
CEL light?
Anyone had any issues with CEL light after installing an aftermarket Header?
I installed the fabspeed header 2 days ago, today was driving it, got a CEL light warning.
Says Bring to Engine Diagnostics Workshop.
Any thoughts?
Old Apr 23, 2007 | 08:52 PM
PorschePhd's Avatar
The headers can not cause a CEL. If you had the exhaust done at the same time it is possiable they didn't tighten the 02s or mixed up locations.
Old Apr 24, 2007 | 12:48 AM
treynor's Avatar
treynor has a spectacular aura abouttreynor has a spectacular aura about
For anyone who is interested, the INNOVA 3130 scantool has no problem interfacing with the 997TT's OBDII system and can display interesting info like EGT, intake temps, ignition retard, etc. It'd also make it much easier to understand why your ECU doesn't like what it sees. For $180 it's a good investment.
Old Apr 24, 2007 | 01:34 AM
mishref's Avatar
mishref is infamous around these parts
Can you reset errors with the innova?
Old Apr 24, 2007 | 09:10 AM
PorschePhd's Avatar
Keep in mind what ever scan tool you use it has to be a CAN system compliant.
Old Apr 24, 2007 | 09:50 AM
treynor's Avatar
So it claims, I have not yet had the occasion to do so.
And it's compatible with CAN.
Old Apr 24, 2007 | 07:02 PM
drbf's Avatar
drbf is infamous around these parts
Who has the INNOVA 3130 for sale?
Old Apr 24, 2007 | 09:26 PM
treynor's Avatar
http://www.google.com/search?q=INNOVA+3130
[they're readily available]
Old Apr 24, 2007 | 09:46 PM
TRK's Avatar
TRK
TRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to behold
Innove 3130
Yup, after Ben said his worked well, I grabbed one. It works fine with CAN, it'll reset error codes, and read out live data Nice little investment.
BTW, we got a car in here with a set of aftermarket headers on it and the drivers side flange was warped about .080" and had a horrible leak. We had to remove it and machine it to stop the leak and get the O2's back in range. You may have the same issue?
It also had an exhaust with some early developmental cats and nearly immediately flagged some cat efficiency codes. P0420/P0430...
aggk
Aug 31, 2015 07:07 PM
GSR Autosport
Aug 26, 2015 05:20 PM
bmwtmx
Aug 26, 2015 07:26 AM
oddjob142
Aug 24, 2015 05:49 PM
