Dealer overfills on oil change - Potential long term damage?
Old Jun 9, 2007 | 12:49 PM
LAT's Avatar
LAT
LAT is infamous around these parts
I brought my car in for an early oil change, 3,000 Km (old school) and the tech forgot to drain the crank and overfilled the engine. There was smoke everywhere by the time they figured it out and the result wa to redrain and refill both and an emberassed tech. The mechanic said there would be no long term effects is this true.
I have never seen this happen in my 20+ years of owning Porsches.
Old Jun 9, 2007 | 01:42 PM
Paris_CarreraS's Avatar
Paris_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the rough
your mechanic should be more carefull with your car...
same thing happened to my dad old 996TT...and the car was smoking too!
I recomend you to go to your dealer and put the right oil level!
hope to help you...
Old Jun 9, 2007 | 01:44 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
Why so early or an oil change though?
Old Jun 9, 2007 | 03:49 PM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
Thats one reason why I do my own oil changes. (I don't trust anyone else to do it). Maybe thats overkill but oil changes have always been reserved for "me". I did a complete oil change at 1000 miles (breakin change) and I will probably do one every 4-5 thousand miles or once a year. Its really easy, didn't even need to jack-up the car. Be prepared though, as soon as you loosen and remove one of the 2 bolts (in the reserve tank) it comes out like Niagra Falls! Make sure your pan holds 12 quarts (9 actually drained out) and read the torque settings for the 2 drain bolts under the car, the oil filter assembly, and the 2 turbos (I did not drain the turbos as they hold little oil). In less than 1 hour your done.
Old Jun 9, 2007 | 04:14 PM
LAT's Avatar
LAT
I too believe that oil is the cheapest part of the motor and thus the oil change at 2000 mile break in point.
I think I learned not to assume just because they are dealer and it is a simple oil change that there is nothing to go wrong.
They paid for the oil change and made a record on the invoice.
Old Jun 9, 2007 | 04:15 PM
N2it's Avatar
N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !
Rent-a-tech! My god he should have known better. It is a friday?
Old Jun 10, 2007 | 12:51 AM
ScottKelly911's Avatar
ScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond repute
There shouldn't be any longterm affects, but keep your nose sensitive because if you smell oil for a while, there may still be oil in places you don't want it. I've overfilled mine (common problem on early 911's especially oddball '72's) and haven't had any problems other than horrible looking smoke and smell.
Old Jun 11, 2007 | 08:58 PM
WOODTSTER's Avatar
I drove this car (LAT's) after oil overfill and it is perfect!!
He also had a Cargraphic (medium?) exhaust on it and it sounds
fantastic. Zero, I mean zero resonance and better power delivery.
His car did smoke upon start up, when he left my house.
Marty
pshep138
Sep 1, 2015 09:45 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
