turbo boost on? 1.0 bar~
Old Jul 9, 2007 | 10:44 PM
997TT HKG's Avatar
997TT HKG is infamous around these parts
Question turbo boost on? 1.0 bar~
Is it normal that sometime even with the overboost on, the meter still showing 1.0 bar instead of 1.2 bar? touched 1.2 bar for less than a sec then only can hold 1.0 bar through accelaration.
Also there is a metalic like sound (spooling/ exhaust/ turbo leaking???) coming from the right rear when the overboost is on.
Do both Turbos boost come on together or one by one?
How do you know if the turbo/ manifold exhausts are leaking?
Please help.
Old Jul 9, 2007 | 11:21 PM
loungedog's Avatar
loungedog is infamous around these parts
Please help.
Are you talking about when your car is modified or when it is stock? If your car is modified, what package do you have?? With that info we can then determine if your car performing properly...
Old Jul 10, 2007 | 01:06 AM
997TT HKG's Avatar
I have installed the followings: Gruppe M air ram, cargraphics headers, cats and mufflers.
Old Jul 10, 2007 | 06:28 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
raise the rear of the car and look for black soot at the exhaust connections (flanges) of the headers/turbo, turbo/exhaust. That would indicate a leak
Old Jul 10, 2007 | 07:48 AM
PorschePhd's Avatar
Welcome to the crappy stock program. Send the ECU in and I can fix that issue Seriously though these are the issues with the stock program. It will also dip down about 5500 and then shoot up right before redline. The stock program has some issues.
Old Jul 10, 2007 | 08:06 AM
997TT HKG's Avatar
So you are saying my car is normal? The problem is the stock ECU?
Old Jul 10, 2007 | 08:10 AM
PorschePhd's Avatar
More or less yes. You will see blips of 1.2 but when it is warmer out 1.0 is more consistant. Overboost as we have seen does not work as it was advertised to the rest of the world. I hardly ever saw 1.2 until the program was changed or it was zero degrees out.
Old Jul 10, 2007 | 11:20 AM
TT Surgeon's Avatar
How do you guys get a BAR reading, mine only shows psi?
Old Jul 10, 2007 | 11:40 AM
PorschePhd's Avatar
Just switch it in the computer settings to read bar rather than PSI. When you go to set it you have a choice.
Old Jul 10, 2007 | 08:48 PM
spyderman's Avatar
spyderman is a name known to allspyderman is a name known to allspyderman is a name known to allspyderman is a name known to allspyderman is a name known to allspyderman is a name known to all
What PSI readings do you get with the stage 3/4 package in sport mode??
Old Jul 10, 2007 | 09:39 PM
PorschePhd's Avatar
I leave mine on the graph and it pegs it until 5K.
Old Jul 11, 2007 | 04:13 PM
sharkster's Avatar
You Addict!!!
Old Jul 11, 2007 | 07:35 PM
PorschePhd's Avatar
LOL, I took it off tonight. 18PSI...stupid stopping gauge. It is not the size, it is the boost
BauerR
Aug 25, 2015 08:58 AM
markski@markskituning
Aug 24, 2015 10:07 AM
TrackOne
Aug 20, 2015 12:56 PM
