UPDATED: Process for 997 multifunction wheel swap / steering wheel removal
Old Jan 7, 2014 | 06:05 PM
  #136
Wheeler's Avatar
Wheeler is infamous around these parts
Originally Posted by Nav5
After watching the video, it was crystal clear. Thanks guys, much appreciated.
Cheers,
NAV
Awesome! What wheel are you getting?? I'm going to send mine off to Dallas Custom before I leave for Daytona later this month!
Old Jun 16, 2014 | 09:50 PM
  #137
caunyd's Avatar
caunyd is infamous around these parts
Hi guys. I currently have a Tiptronic steering wheel with no multifunction. I want to convert my current Tiptronic wheel into a multifunction Tiptronic wheel using this:
http://www.suncoastparts.com/product/997MFSWX.html
I plan to use Joycon and use the multifunction buttons to control a Nexus 7 tablet that I will use as my navigation/audio system. My question is: where can I find a wiring diagram so that, in the attached pictures, I can identify each wire by color and what it does. Thanks!
ID:	388220   Click image for larger version
Old Aug 16, 2014 | 04:17 PM
  #138
cjcam930's Avatar
cjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond repute
Hi All,
I just swapped a 997.1 MFC wheel for an XPA Sport wheel, which went OK except that now I've got an airbag light! I also had to swap the airbag for the round sport version which I bought new from Suncoast.
I'm wondering if the issue is that I re-used the harness and control unit from the MFC wheel? I just left the MFC connectors unhooked, obviously, and taped them out of the way. AFAIK I connected the airbag properly and those connectors appear identical on the triangle airbag and round airbag.
Any ideas? Thanks!
Old Aug 16, 2014 | 05:18 PM
  #139
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
If you turned on the ignition at any time while the airbag was disconnected, the airbag light will come on and will have to be re-set with PIWIS. I've never had any trouble swapping wheels/bags as long as the ignition was left off until everything was re-connected.
Old Aug 16, 2014 | 05:31 PM
  #140
cjcam930's Avatar
Thanks! Yep I think that is my situation. I drove the car around the block with no airbag to ensure the wheel was on straight. Then I disconnected the battery and waited again, and installed the airbag.
It is definitely not a physical connection/disconnection issue as I just popped-out the airbag again (with power off, again) and all connections look as expected.
So, instead of going to the dealer for this I may bite the bullet and get Durametric as I know it will come in handy down the road.
Old Aug 18, 2014 | 04:37 PM
  #141
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
I think its a thing with the airbag systems that that if the airbag controller gets power (ignition) and some part of the airbag system isn't found by the controller (bag or its light in the dash) then it locks in an error condition that keeps the light lit until its cleared. Not sure but I'd expect a PIWIS certainly but also a durametric of any type would be able to clear the fault.
Old Nov 6, 2014 | 04:55 AM
  #142
maarten22's Avatar
maarten22 is infamous around these parts
Does anyone know the part number for the metal plate that's on the bottom of the round airbag? My airbag came without the plate.
Old Nov 7, 2014 | 02:13 AM
  #143
maarten22's Avatar
Plate is not a separate part, ordered a new airbag. Thank you Ryan at Suncoast for looking this up!
Old Jul 12, 2015 | 01:18 AM
  #144
j66's Avatar
j66
j66 is infamous around these parts
Originally Posted by p0rsch3
Here's some pics from Sunset Porsche:
1. PET schematic
2. Parts prices
i recently swapped macan turbo s steering on my 987.2 cayman PDK. paddle shifter works, but not the multifunction buttons. at night, those buttons don't even lid up.
i got the macan steering used, and it shows it has the controller and since it has the control and buttons i'm sure the harness is correct. i'm thinking if it might be just the wiring on the plug. does anyone have the wiring of the macan? where can i obtain this?
thanks,
Old Aug 15, 2015 | 10:37 AM
  #145
no1joey's Avatar
no1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to all
Hey guys resurrecting an old thread, it says on this thread that the torque setting for the steering wheel centre bolt is 37 lb/ft, and the torque settings for the airbag module is 7.5 lb/ft,
Can anyone else confirm this?
Old Aug 15, 2015 | 03:36 PM
  #146
tphan's Avatar
tphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond repute
37 lb/ft sound correct for center bolt, had it marked but couldn't find the picture when did mine, if use loc-tite use the blue stuff and dont go crazy on it.
Not sure about the airbag module, I didn't had to mess with it.
Old Aug 15, 2015 | 07:35 PM
  #147
no1joey's Avatar
Chhers
Old Aug 15, 2016 | 04:59 PM
  #148
ALEV8's Avatar
ALEV8 is infamous around these parts
Inside Job here in Dallas. Recommended by Park Place Porsche.
Old Aug 16, 2016 | 03:21 PM
  #149
Derek Zoolander's Avatar
Derek Zoolander is infamous around these parts
Can someone tell me if this is a 997.1, 997.2, or 991 airbag? I haven't seen anyone retrofit a 991 wheel/airbag to a 997.
I have a 997.1 with MF wheel that I'm looking to change to a round sport wheel. Can I just get this airbag and a 997.2 wheel? Will the 997.1 trim surround piece work with this airbag? Will my MF module fit behind a sport wheel airbag?
http://www.ebay.com/itm/PORSCHE-DRIV...p2047675.l2557
Old Oct 16, 2016 | 10:39 PM
  #150
Marek C's Avatar
Marek C is infamous around these parts
I've recently retrofitted the 991 paddle steering wheel onto my 997.1 turbo with the upgraded control module. We downloaded the information from the old steering wheel control module onto the new one and activated the pdk function through piwis but the paddles still don't work.
Does anyone have the exact method through piwis to activate the paddles?
Any help would be appreciated.
You have already rated this thread Rating: Thread Rating: 1 votes, 2.00 average.
