Will 315 Tires fit on my 19" Carrera S wheels?
Old Oct 28, 2008 | 11:41 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
Will they fit on or will I have to use spacers?
If so what size spacers?
Old Oct 28, 2008 | 11:54 PM
20C4S's Avatar
if i understand ur question correctly, no. spacers are used to space out the wheel from the brake hub. has nothing to do with the tire. if ur wheel is not wide enough the tire would not fit on it properly.
Old Oct 29, 2008 | 12:08 AM
mobonic's Avatar
My rear wheels are 11" wide.
From what i have read online a 315 mm tire should fit fine on a 11" wheel.
My question is: Has anyone on here run a 315 on the rear of their 997 or 997S?
Old Oct 29, 2008 | 12:10 AM
20C4S's Avatar
ic. thought u're saying stock wheel which is not 11''. 11'' for 315 is fine just watch for the correct profile.
Old Oct 29, 2008 | 12:16 AM
mobonic's Avatar
315/25/19
Old Oct 29, 2008 | 12:20 AM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
You might have an issue with rubbing. It seems most people don't go wider than a 305 tire on a NB. However I could be wrong.
Old Oct 29, 2008 | 06:32 AM
NorthVan's Avatar
Mobonic,
Why would you want to put 315 on your car?
Old Oct 29, 2008 | 11:27 AM
mobonic's Avatar
got a good deal on a set for the track.
Old Oct 29, 2008 | 11:31 AM
blakt out's Avatar
blakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond repute
I'm running 315s on 18X11.5" wheels with a 7mm spacer on my 997S. No rubbing, but I'm also running -3.2 degrees of camber, which could be why I'm not rubbing. Also, this is not with a stock suspension, but with Motons, which ALSO might keep it from rubbing.
Old Oct 29, 2008 | 12:01 PM
NorthVan's Avatar
OK that is a good reason, what kind of tires are they?
Enemy
Nov 10, 2015 08:01 AM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
