Check engine light from aftermarket intake?
Old Nov 19, 2008 | 09:50 AM
Nitro911s's Avatar
Nitro911s is infamous around these parts
I installed an evolution intake in my 08 911S about a month ago and just had a check engine/visit workshop light pop up on my dash..I havnt had it checked yet, but im almost 100% sure its the mass flow sensor..
Is there anywhere i can buy the sensor online instead of going to the dealer?
Is there a different filter i can put on the evolution intake that wont mess up my filter?
Old Nov 19, 2008 | 10:09 AM
NorthVan's Avatar
I am running an EVO intake, and I don't have any problems with it. Did you oil it before the install? If so it might have a film on that needs to be cleaned. I would try that first.
Old Nov 19, 2008 | 10:44 AM
Nitro911s's Avatar
No i did not oil it when i installed it, when i put it in it didnt feel like it was oily either..same thing happend to my mercedes when i put a k&n filter in it, so i figured it was the filter.
Old Nov 19, 2008 | 12:03 PM
NorthVan's Avatar
Odd, check your MAF, clean it and try it again. I would then try with replacing it.
Old Nov 19, 2008 | 12:09 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Evo tells me they are now using a cotton gauze filter that can be used w/o oil. I wonder whether the few hp are worth the potential problems w cel and the long term effects of questionable filtration? So far I have resisted the temptation.
Old Nov 19, 2008 | 12:13 PM
surfingbuddhist's Avatar
surfingbuddhist has a spectacular aura aboutsurfingbuddhist has a spectacular aura about
Most independent shops can scan the code for you for a nominal fee...
Old Nov 19, 2008 | 10:00 PM
Andre5's Avatar
Andre5 is infamous around these partsAndre5 is infamous around these parts
I experienced the same problem right after I installed my Evo intake. However, the CEL turned off after about 1 minute of idling. Make sure the connectors are on nice and snug.
Old Nov 20, 2008 | 06:12 AM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
I had no problem with my Evo. I have seen on posts that alot of people have a problem with kn
Old Nov 20, 2008 | 09:11 AM
Nitro911s's Avatar
I checked it out and its reading " system running lean at idle bank 1 and bank 2"
Is that the MAF sensor?
Old Nov 20, 2008 | 10:58 AM
LarryP's Avatar
LarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to all
I had the same problem with my K&N i had the mas Flow in backwards take a sec pull it out make sure the open part is facing toward were the air is coming in.it went right away once i faced it that way
tropicatango
Jun 8, 2025 01:00 PM
COBB Tuning
Jan 1, 2025 09:02 AM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
