1st GEAR
Old Jan 14, 2009 | 07:46 PM
  #31
B R A N D X®'s Avatar
B R A N D X® is infamous around these parts
Originally Posted by m5_2010
Are you flooring it? I have no problem like the one you describe. It may be due to the fact that I have not floored it due to low mileage.....
Sometimes yes, but I'm not much of a jack-rabbit-start driver. The problem I'm referring to tends to happen when pulling off gently as in normal pulling away from a traffic light or stop sign. It's happened maybe 10 times total in 3800 miles.
Old Jan 14, 2009 | 08:33 PM
  #32
500's Avatar
500
500 is infamous around these parts500 is infamous around these parts
Originally Posted by NorthVan997C2S
I bet the sofware problems that arise with the PDK will make this look like nothing, oh yeah it is nothing. This is a syncro problem, not sure the dealer will even go beyond a road test and tell you this is normal.
When I test drove an 09 S PDK it had the herky jerkies a few times when in auto mode and at very slow speeds...nothing a software fix shouldn't be able to correct (one would hope )
Old Jan 14, 2009 | 08:35 PM
  #33
Michael2364's Avatar
Michael2364 is infamous around these parts
My car does it all the time for the first 5 min or so. If you double clutch it before going into 1 it should slide right in. It works on my car.
Old Jan 14, 2009 | 08:47 PM
  #34
500's Avatar
500
You very fortunate yours only does it when cold...mine is hard to get into first even when hot sometimes.
Old Jan 14, 2009 | 11:11 PM
  #35
lig's Avatar
lig
lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !lig Is a GOD !
Mine is balky into first when cold. It's also reluctant to go into 2nd when really hot (track days)
Was thinking about changing tranny fluid to see if that might help and the recommended mileage was something crazy like 120K?!?
Blasphemous - but I like my S2000 gearbox/tranny better.
Old Jan 14, 2009 | 11:17 PM
  #36
aggie57's Avatar
aggie57 is a jewel in the roughaggie57 is a jewel in the roughaggie57 is a jewel in the roughaggie57 is a jewel in the rough
Mine is the same when cold. Fine when warm. Over the years I've had several different types of cars that are the same, particularly Alfa's. By slipping it into a higher gear first I've always thought I stop the box turning so it goes into first easier then. Sound reasonable?
Funnily I actually find these odd quirks nice things about these sorts of cars......
SlinginHoss
11
Oct 8, 2025 05:16 PM
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
panas001
Sep 27, 2015 02:51 PM
