p21w LED switch front turn signal
Old Mar 23, 2009 | 05:17 PM
C2SKID's Avatar
C2SKID is infamous around these parts
Anyone ever seen a 997 running these bulbs. Check out these videos.
http://www.youtube.com/watch?v=NDwgQu8Dgr4
http://www.youtube.com/watch?v=zRKAd...eature=related
http://www.youtube.com/watch?v=P5N4d...eature=related
http://autolumination.com/1156_1157.htm
Introducing the Switchback
10mm diameter - Direct drop-in replacement for all OEM bulbs
Fully Regulated - Non-Polar Proprietary Circuitry. Protected Under (US Patent # 7,345,433)
Don't be fooled by imitations, these are not available anywhere else!
1157 Combination Amber and White LED Tower Bulbs
1157 Replaces 1016 1034 1076 1130 1154 1158 1493 2057 2357 2397 7528 Two Colors - One Bulb
CLICK HERE To See How This Operates
Old Mar 23, 2009 | 07:20 PM
Bara's Avatar
Bara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant future
Old Mar 23, 2009 | 07:33 PM
C2SKID's Avatar
If you look at my avatar, You can see my turnsignal bulb. If that was a LED white it would fill out my fog light casing, and Nice to have it flash Amber for signals.
Old Mar 23, 2009 | 08:02 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
that's kind of cool- get a set and try them out!
Old Mar 23, 2009 | 08:24 PM
C2SKID's Avatar
Found these below. What bulb is front signals? I think it is P21w or is it PY21w? I am emailing company for help. Any electronic or lighting guys have any ideas??
http://www.v-leds.com/Exterior-LED/T...-p5168714.html
Old Mar 24, 2009 | 08:41 AM
gmoney's Avatar
wont work, the car will throw a code at you and the bulb wont ignite - same goes for swapping LED's in any of the fitments on the exterior that are monitored by the cars bulb out warning system.
You can install some resistors at the same time to get it working but theres not much room for those.
Old Mar 24, 2009 | 11:20 AM
Taiwanese's Avatar
Taiwanese is infamous around these parts
I just purchased P21W from Walmart for $2.76 (2 bulbs) to be used on my C230. It's not LED but the original bulb lasted 6 years.
Old Mar 24, 2009 | 12:24 PM
C2SKID's Avatar
I replaced my w5w parking lights with PIAA LED from Japan with ECU ERROR Blocker works greats! The I used PIAA H8 Foglight bulb from Japan and that one worked great. I have a pic in my album labeled 997.
Old Mar 24, 2009 | 04:03 PM
C2SKID's Avatar
Old Jul 16, 2009 | 12:50 PM
drolling's Avatar
drolling is infamous around these parts
C2SKid,
Can you tell me where you bought the lights, resistor, rough cost and installation instructions?
Much appreciated
Old Jul 16, 2009 | 01:07 PM
C2SKID's Avatar
I never bought the switchbacks was hoping someone on here with a shop would figure it out. I bought PIAA LED for the w5w and foglights.
http://www.cargym.com/
Old Jul 16, 2009 | 01:08 PM
C2SKID's Avatar
Does anyone have a shop and is good with porsche electronics? These switch backs would look amazing and with a new led bar put in the front
Old Jul 16, 2009 | 03:27 PM
drolling's Avatar
LED lights
Just to be clear you are referring to the fog lights that are in the main circular housing? The parking lights are the separate horizontal bar below the main lights? Which of the bulbs w5w or H8 is for the separate horizontal bar below the main lights as that is the only one I want to install.
Have you had any of the browning issues from heat (I would assume no as LED has lower heat) also do you get the bulb out error message with the Piaas?
Old Jul 16, 2009 | 03:49 PM
heacuva's Avatar
heacuva is infamous around these parts
Originally Posted by Bara
true story
Old Jul 16, 2009 | 04:02 PM
gmoney's Avatar
the horizontal bar sits the H8 bulbs, I think yellow ones would look better, I installed Hoen in the turbo, not a fan of the blue LED look, bit ricey for my tastes, but yellow looks good and offers an actual benefit in the rain and fog.
