What is the difference between an Carrera & a Carrera S?
Old Jan 24, 2010 | 12:36 PM
msgm1's Avatar
msgm1 is infamous around these parts
What is the difference between a 2007 Carrera Cab abd a 2007 Carrera S Cab please?
Old Jan 24, 2010 | 12:43 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
The S models have a 3.8l 355HP engine vs a 3.6l 325HP engine, and (active) PASM suspension vs non-PASM suspension.
And yes... as noted (reply #3) S models come with 19" rims.
Old Jan 24, 2010 | 12:48 PM
philcr2800's Avatar
philcr2800 is infamous around these parts
S also come with 19" rim, sport steering wheel, white dashboard and can have additional options such as sport chassis, X51. Another difference is 11 grands.
Old Jan 24, 2010 | 01:22 PM
Auto_Union's Avatar
Auto_Union is a jewel in the roughAuto_Union is a jewel in the roughAuto_Union is a jewel in the rough
The S has:
40 more horsepower
PASM (Porsche active suspension management) which is only of use at the track unless you live in an area where the roads are in excellent condition - Available on the non-S for additional cost
19" wheels - Available on the non-S for additional cost
red painted brake calipers
white faced gauges - Available on the non-S for additional cost
S badge on the rear
You'll have to choke up another 11 grand to get into the S and that's before all of the more popular options such as Bose, Bluetooth, iPod interface, Powered seats w/ driver's side memory
Old Jan 24, 2010 | 01:26 PM
adias's Avatar
Originally Posted by Auto_Union
The S has:
40 more horsepower
On an '07 997.1 the S has an additional 30HP. It's on the '09/'10 997.2 that the diff rises to 40HP.
Above I failed to mention the S bigger brakes (red calipers notwithstanding). These brakes are better and easier to service.
Old Jan 24, 2010 | 01:39 PM
Jafetica888's Avatar
Jafetica888 is a splendid one to beholdJafetica888 is a splendid one to beholdJafetica888 is a splendid one to beholdJafetica888 is a splendid one to beholdJafetica888 is a splendid one to beholdJafetica888 is a splendid one to beholdJafetica888 is a splendid one to behold
Guys,
a few more differences 997S vs non S:
• Engine, Brakes, Suspension different
• PASM standard on S
• Bi-Xenon standard on S
• 19" & wider wheels/tires (rear) standard on S
• S rides about 1/2" lower
• S is about 55# heavier, gets 1 mpg less
• different steering wheel, different instrument dials and dashboard trim
• different exhaust tips,
• S is .2 to .3 sec quicker in straight line 0 - 60 mph
• Standard will ride a little bit smoother on the 18" wheels and withstand pot holes a bit better.
Old Jan 24, 2010 | 01:59 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
Originally Posted by Jafetica888
Guys,
Amazing what you can learn from others. I never realized the steering wheel in my S had a smaller diameter (@ 14.5") than the non-S model. I've read the "The New 911" booklet from my dealer a dozen times but somehow ended up missing this little tidbit. Ahem...so, size does matter, heh?!?!
Old Jan 24, 2010 | 02:35 PM
Auto_Union's Avatar
As adias pointed out some feature differences depend on whether we are talking about a 997.1 or 997.2. Since I never owned a 997.1 I tend to think in terms of 997.2. Here's something else I noticed with the 997.2. It seems that the Sport Steering Wheel and Bi-Xenon headlights which were options on the non-S 997.1 now come standard on the non-S 997.2. I'm not sure about the diameter of my steering wheel but as standard it now comes with the thumb rests and the round center as opposed to the triangular center in the 997.1. To get the thumb rests and round center on the 997.1 you had to select the sport steering wheel option which I believe was something like an additional $240 (feel free to correct me if I'm wrong).
Edit: Actually I think the change to the round center steering wheel as being standard only applies to the 2010 model year.
Old Jan 24, 2010 | 02:40 PM
BillyJoelR's Avatar
BillyJoelR is infamous around these parts
So it seems that $11K for an "S" is worth it.
Old Jan 24, 2010 | 03:44 PM
mickfluff's Avatar
mickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant future
nope, not always....
not if your buying used and if this porsche is a faster better performing car then what your coming from.... if your driving a zo6 vette the S will feel better then the none S.... if your driving a none sports car or low end sports like car like a Mitz Eclipse etc the none S will treat you just fine and be hard pressed to feel the differences. If your buying used you can find a well optioned none S car with nearly all the options of an S car minus the HP/added power and the larger brakes all day long. (some you can ever find with the brakes and possibnly more options)
The hunt is half the fun..... The S is a great car, but not always worth the extra $
Old Jan 24, 2010 | 04:45 PM
Auto_Union's Avatar
In my case the only reason to get the S would have been the extra horses but if you do the math that's $275 for each extra horse. If you hang around the glue factory long enough you could probably buy a real horse for that.
As the little girl in that commerical says, "You didn't say I could have a real one"
All of the other S goodies didn't have any value to me, especially PASM since I have no intentions of putting the car on the track. I wish I could have purchased a device that could raise the car, not lower it. Yes, I know the GT3 has an optional front axle lift but it's like $3400 which is crazy.
Old Jan 24, 2010 | 05:21 PM
adias's Avatar
... All of the other S goodies didn't have any value to me, especially PASM since I have no intentions of putting the car on the track.
I would think it is the other way around. PASM is an active mechanism to deal with the wide variations of street/road pavement unevenness. For track only a fixed suspension is just fine.
Old Jan 24, 2010 | 05:36 PM
Auto_Union's Avatar
adias,
The problem with PASM is that is lowers the car. Have you ever driven in New Jersey? Our roads are in such poor condition and also driveways and other entrance aprons are sloped at angles that aren't exactly what you would call Porsche friendly.
My base 997 is already too low for New Jersey roads. Lowering the car further would not be a good idea. Oh, and don't even think about an aero kit or any other kind of bumper or ground effects that make the car lower to the ground if you live here.
Old Jan 24, 2010 | 05:50 PM
buck986's Avatar
buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !
I went base and 05 model due to the fact i wanted to take it to the track as a novice. (everyone says get the S for the track but I think for the novice the base is fine) The car is plently fast, I had a great time last year, learned a ton of stuff and the money I saved not going to the S can go toward mods for track use in the future.
You can not go wrong with any model. Good luck.
Old Jan 24, 2010 | 06:42 PM
msgm1's Avatar
Thanks for all the replies guys!
Guess the S and non S are the same body width unlike in the 993 series?
