Stuffed Bose Subwoofer
Old Jun 8, 2010 | 07:20 PM
Gator Skin's Avatar
Gator Skin is infamous around these parts
My wife donated this pillow to be sacrificed for the mod. Very easy to do. Removed port to stuff box pretty full then re-installed. Sounds real nice, a noticeable improvement but the bass had to be adjusted; turned it up a bit because it was tighter but quieter. Great info on this board and planet9 about the install.
Old Jun 8, 2010 | 07:31 PM
atr911's Avatar
atr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud of
How did the sound change? Tighter?
Usually one stuffs boxes to emulate a larger volume enclosure.
Old Jun 8, 2010 | 07:59 PM
Gator Skin's Avatar
LOwer tighter and less boomy but not as loud so had to turn the bass up
Old Jun 9, 2010 | 06:58 AM
Burg Boxster's Avatar
Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !
Hmmm, interesting. Thanks for sharing. More details or a link please.
Anyone else try this yet and what are your perceptions?
The Bose box does get pretty boomy especially top down at hwy speeds.
Thanks!
Old Jun 9, 2010 | 07:07 AM
Gator Skin's Avatar
Old Jun 9, 2010 | 07:08 AM
xXxGhotimanxXx's Avatar
xXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond repute
How much does the pillow weigh? And what is the net weight gain after the lost bass? Does anyone know if Porsche makes a pillow?
J
Old Jun 9, 2010 | 07:27 AM
henrysko's Avatar
henrysko is infamous around these partshenrysko is infamous around these parts
"P" pillow!
Old Jun 9, 2010 | 08:41 AM
Gator Skin's Avatar
I did a before and after dyno and it conclusively shows a 22 HP increase at the wheels.
Old Jun 9, 2010 | 08:47 AM
damon@tirerack's Avatar
Moderator
J
Hahahaha, Bravo.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jun 9, 2010 | 09:02 AM
RH512's Avatar
RH512 is infamous around these parts
Good info
some more relevant info on stuffing here - http://www.moodym.com/audio/fiber.html
and Acousta-Stuf superior material for stuffing here -
http://www.parts-express.com/pe/show...number=260-317
Old Jun 23, 2010 | 03:08 PM
Just a quick follow up here, I took it a step further. Picked up the smallest bag of poly-fil at JoAnn Fabrics for $2.99 (still have 3/4 of the bag left too...) - no it's not N-spec
Anyhow, instead of trying stuff the filler in thru the port, just unscrew the 6 (IIRC) torx screws holding the driver and grill in/onto the bottom of the box. No need to disco the wires to the driver, just lift it out of the enclosure and place to the side. Then using your hands, stuff the poly-fil in from here into all the corners, crevices and open space in the box. Firmly but loose I think is the technical measurement . Then just replace the driver, grill and 6 torx screws into the enclosure and reinstall the enclosure back into vehicle.
Very noticeable difference in the subs response - a little deeper but much tighter eliminating a lot of the boomy-ness especially top down.
Excellent mod for $2.99 and 15 min.
Thanks again Gator Skin for posting and the link
Old Jun 24, 2010 | 08:28 AM
Gundo's Avatar
Gundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud of
Have done the same - followed the mod instructions on the planet-9.
Works amazing well - bass is MUCH tighter and "punchier" especially in my cab.
Thanks for highlighting this one.
Gundo
Old Jun 24, 2010 | 02:20 PM
getz's Avatar
getz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud of
Will this mod void my warranty?
-Getz
Old Jun 24, 2010 | 04:54 PM
Axxlrod's Avatar
Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !
Will dealer be able to tell that I've done this mod?
Old Jun 24, 2010 | 08:05 PM
simba88's Avatar
simba88 is infamous around these parts
Thanks for the post. I have been on this forum for a while but have never posted anything. This mod was so great I had to post something and thank you guys.
Thanks for the tip and a wonderful forum!
