Clutch issue? Not sure what to do.
Old Jun 21, 2010 | 02:34 PM
NorthVan's Avatar
Originally Posted by sin911
No, I don't. I didn't replace the clutch so I didn't want to spend so much money on labor...
I want to spend my money on seats/roll bar/harness & wheels/tires next
I installed it on my car and there was about 70% clutch life left. I just sucked it up, as the I put a LSD in at the same time....two mods I highly recommend especially if you track.
Those other mods are also great, must have a set of LW wheels for the track
Old Jun 21, 2010 | 02:44 PM
mike123's Avatar
mike123 is infamous around these parts
I have a 2002 996tt Dealer wanted $5,000 to put a clutch in. I put in myself with a engine and transmission jack I made myself, it took me only one day to drop the motor and trans and put them back in the car. One of the easiest cars I have ever worked on.
Old Jun 21, 2010 | 05:08 PM
MichaelL's Avatar
MichaelL is infamous around these partsMichaelL is infamous around these parts
If the clutch is being changed out anyway at your expense, consider a heavy duty unit. the cost differential is probably only a few hundred dollars. Think twice about a lightweight flywheel, many recommend against using this in a street vehicle unless you really need it, due to drive-ability issues. Same with limited slip, if you are not tracking the car, it may not do you a lot of good.
From your post, it looks like you are relatively new to the car and the clutch problems can probably be blamed on the previous owner. Don't get carried away with high performance modifications that you don't need.
Old Jun 21, 2010 | 07:15 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
I'm just going to go with a stock replacement. Like MichaelL stated, I'm new to the car and don't plan to track it much. An occasional AX and maybe a DE or two. I'm not at a place in life where dropping a bunch of money into a hobby of that level of commitment makes sense. I see the value in learning to push the car to the limits on a designated area and plan on learning how to handle it better but as far as turning into a weekend track junkie, it's just not in the cards right now.
Old Jun 21, 2010 | 07:54 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
Originally Posted by Hella-Buggin'
$1900.00 baby.... now I'm in the doghouse with the wife...
"I knew we shouldn't have bought that damn car.... we should have bought a rental property instead!"
Although, she's the first to say "we're taking the porsche right!" whever we go somewhere.
Oh man, give it some time and you will swallow $1900 as a peanuts... I am already over $10K for this season alone and it keeps coming. It is a major money eater.
Old Jun 22, 2010 | 08:58 PM
Well, got the car back with a brand new clutch in it. Wow, I can't believe how different it feels. My clutch must have been shot. The clutch grips right towards the bottom of the pedal now instead of 1/2 way. The feel is much smoother as well instead of this hard spot.
All in all it was $1800 with my PCA 20% off ecoupon.
Old Jun 22, 2010 | 09:03 PM
sin911's Avatar
sin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond repute
My clutch is gripping towards the end of high end... I will drive it until it is completely gone.
Old Jun 22, 2010 | 09:06 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
That is strange. The clutch on the 997 is self-regulating - its take up point should not vary much.
Old Jun 22, 2010 | 09:08 PM
sin911's Avatar
I dunno... Taking off on a ramp is getting harder and harder, even on normal surface. It is not sensitive.
midwestamv8
Audi
Sep 9, 2015 11:53 AM
LiquidElephant
Aug 27, 2015 06:17 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
