DIY oil change help please
Old Jan 22, 2011 | 04:45 PM
Atxjaz's Avatar
Atxjaz is infamous around these parts
Hey everybody. So I decided to change my oil myself this time, many thanks to the excellent DIY write up by JEllis, https://www.6speedonline.com/forums/...ed-dragon.html (thank you very much if you're reading this, great write-up with great pics)
I bought everything I need, although I'm trying to do it without jacking up the car...I've got a driveway that slopes up to the garage, and I can slide under well enough to see the filter housing and drain plug.
Here's my problem, the first one anway: I can't get the filter off! I attached the filter wrench (type B which I bought from AutoZone) which appears to be a great fit, but I can't rotate the dang thing a single bit. I'm going counter-clockwise but it just won't budge. The only thing I've accomplished so far is the ratchet slipping out causing me to badly scrape my left hand (pics available upon request).
I guess the second thing I'm worried about is what if the drain plug is the same way?
Any help is great appreciated!
Old Jan 22, 2011 | 05:03 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
Hey,
Glad you like the write up!
Is your filter wrench plastic? The OE filter wrench is metal and I think its a little better. However, the filter should not be on super tight. If your not jacking up the car you might have a leverage problem.
Jason
Old Jan 22, 2011 | 05:11 PM
Atxjaz's Avatar
Thanks for getting back so quick Jason. It is a metal wrench, here's the link to the one I'm using:
http://www.autozone.com/autozone/acc...ier=153158_0_0_
It's not really adjustable so I don't know how to make it super tight vs not super tight.
Yeah, I'm not jacking up the car...I don't have a jack. I don't know that it's a leverage issue, although suppose it could be, but I feel like I'm getting a good amount of force applied. I wonder if I'll need one of those big tools with the ratchet in the middle so I can pull with one hand and push with the other. Should I be worried about applying too much force?
Asim
Old Jan 22, 2011 | 05:26 PM
JEllis's Avatar
Well the filter housing is just a plastic piece so you may just have to put some more force into it. I would not worry about putting too much force. The last service dept probably just tightened it too much.
Jason
Old Jan 22, 2011 | 05:58 PM
wbellinz's Avatar
wbellinz is infamous around these parts
Buy an adapter to go from 3/8 to 1/2" drive. Then use a longer 1/2" rather. That should give you the extra umph it sounds like you need. Or just slip a pipe over your 3/8" rachet.
Old Jan 22, 2011 | 06:24 PM
cbzzoom's Avatar
cbzzoom is infamous around these parts
"I'm going counter-clockwise but it just won't budge."
counter-clockwise from lying on your back looking up at it, or counter-clockwise from having your head above it and just reaching under?
Just give it some mustard. Shops love to over-tighten these things. I keep a spare housing on hand cuz I broke mine taking it off the first time.
Old Jan 22, 2011 | 06:50 PM
Atxjaz's Avatar
Counter clockwise while on my back looking up at it.
Wbellinz, I'll try the adapter tomorrow if more oomph doesn't get it done. My longer handeled ratchet is a 1/2 inch drive while the filter wrench requires a 3/8 inch drive.
Old Jan 22, 2011 | 06:53 PM
Atxjaz's Avatar
cbzzoom, how did you end up getting the broken filter housing off? Hopefully I won't have to face that situation.
Old Jan 22, 2011 | 07:55 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
I do my own oil changes, and I use the same socket wrench tool that dealers use, it's a perfect fit. I paid about $36 for it, and while pricey, it's better than breaking the plastic filter housing once or twice.
Use one of these, and a breaker bar for greater torque if you need to.
CATTMAN
Old Jan 23, 2011 | 06:14 AM
NC 997's Avatar
NC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant future
"Righty-tighty.. Lefty-loosey".. sorry, couldn't help myself..
Old Jan 23, 2011 | 09:19 AM
VTach's Avatar
VTach is infamous around these parts
I've got the exact filter wrench that CATTMAN posted above. I'm also in Austin so send a PM if you need a hand or want to borrow the wrench.
Old Jan 23, 2011 | 09:42 AM
Boatsonthebrain's Avatar
Boatsonthebrain is a name known to allBoatsonthebrain is a name known to allBoatsonthebrain is a name known to allBoatsonthebrain is a name known to allBoatsonthebrain is a name known to allBoatsonthebrain is a name known to all
CATTMAN
Cattman, did you pick up your socket wrench tool from a dealer or is there an online source? Tnx
Old Jan 23, 2011 | 09:50 AM
Cattman's Avatar
My tech at my dealership got it for me. It's just a Porsche OEM oil filter wrench socket. You can order it from PelicanParts, right here:
http://www.pelicanparts.com/cgi-bin/...30%31%30%29%20
Mine looked a little different, as it had a 3/8 inch socket hole in it. They are available from SnapOn, too.
CATTMAN
VTach's Avatar
Old Jan 23, 2011 | 10:07 AM
Originally Posted by VTach
Thanks Cattman & VTach!
