creaking after sways were put on
Old Jun 8, 2011 | 10:44 AM
dk10438's Avatar
dk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to behold
Hi
I recently put on some H and R sway bars and now I have an annoying low speed creak, especially when slowing down or when going over drive ways. Here's my setup
07 C4S w/ PASM
Bilstein damptronic coilovers
Front and back H and R sway bars at the intermediate setting.
took it back to the installer and they "re-lubed" the sways which helped for about 300 miles.
Now the creaking is back
Old Jun 8, 2011 | 10:48 AM
Rxxxdruggist's Avatar
Rxxxdruggist is a jewel in the roughRxxxdruggist is a jewel in the roughRxxxdruggist is a jewel in the rough
it's normal to have creaking sways especially if they did a poor job lubing the bushing. the installer has to lube the inside of the bushing. take it back again and see if they could remove the bushing to have it re-lubed.
Old Jun 8, 2011 | 11:00 AM
dk10438's Avatar
so if it's normal, what's the point of taking them back?? isn't it just going to ended up creaking later??
Old Jun 8, 2011 | 11:06 AM
it's not normal if they packed the bushing correctly...when the grease dries out (eventually) that's when it creaks.
Old Jun 8, 2011 | 11:08 AM
trackaddict's Avatar
trackaddict is infamous around these parts
See if you can find a teflon coated bushing...those don't ever need to be lubed up. I've seen these for other cars, but I'm not sure if there's a Porsche application.
Old Jun 8, 2011 | 02:47 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
I pretty much have the same set up as you but without any creaks. I don't remember having to do any special lubrication when the sways were installed about a year (~6,000 miles) ago.
According to the marketing spiel from AWE Tuning where I bought mine, "All H&R swaybars use a teflon mesh lined bushing to eliminate squeaking under movement and the need for periodic lubrication. Trust us when we say that this is a terrific idea!" You might want to call H&R directly to discuss. GL,
Old Jun 9, 2011 | 12:04 PM
Josh/AWE's Avatar
Originally Posted by dk10438
Hi
07 C4S w/ PASM
Just speculating here, but my first inclination is that you are hearing something from the coilovers, not the swaybars. Those teflon lined H&R bushings are magic. I have had owned several cars and drivn countless cars with H&R bars we have installed and never a peep.
Can you have the coilovers looked at?
Old Jun 9, 2011 | 12:32 PM
dk10438's Avatar
coilovers went on first so i'm pretty familiar with all the clunks associated with them. i've tried everything includeing nylotron washers, replacing the strut bearings, etc.
the creaks started after the sways went on so i'm pretty sure it's from that.
BenTT
Jul 22, 2021 02:38 PM
Rguy
Apr 12, 2020 11:11 PM
RyanWoon
Sep 19, 2015 09:16 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
flewis763
Sep 9, 2015 11:11 PM
