How to set Garage Door Opener on 997.1S?
Old Aug 1, 2011 | 02:22 PM
Ballgie's Avatar
Ballgie has a spectacular aura aboutBallgie has a spectacular aura about
Anyone have experience how to set the homelink garage door opener on 2006 997s? I did follow the user manual and step by step but still can't successful. But it is easy setup on my 2011 Panamera 4. Stange.....
Old Aug 1, 2011 | 02:59 PM
DoninDEN's Avatar
DoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond repute
So you held down one of the buttong in the car until it started blinking, then walked around the front of the car, pointed the remore at rhe front of the car and held the remote button down until lower lights flashed and it did not work?
Maybe check the batteries in the remote or try the reset function as described in the manual?
It worked great for me.
Old Aug 1, 2011 | 03:47 PM
Ballgie's Avatar
I did try that many times but still no good. The funny thing is I use same method on my new Panamera 4 and it works right away. I will try that again tonight and see my luck.
Old Aug 1, 2011 | 03:50 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Sometimes you have to also press the learn button on the garage door opener too. Once the car has learned the code.
Old Aug 1, 2011 | 04:18 PM
jhbrennan's Avatar
Try here -
http://www.homelink.com/program.php
Fnulli997tt's Avatar
Fnulli997tt is infamous around these parts
Sorry but not sure I understand this?
I also have the the same problem with my 997tt.
Old Aug 1, 2011 | 04:25 PM
jhbrennan's Avatar
All the info you need is in the owners manual and homelink link I posted.
Old Aug 1, 2011 | 04:57 PM
I know and I tried it 100 times without any luck
My fog lights flashes 3 times but I just can't get it to open any of my garage doors
Old Aug 1, 2011 | 04:58 PM
Ballgie's Avatar
haha.. exactly same as my problem.
Old Aug 1, 2011 | 05:02 PM
jhbrennan's Avatar
Did you guys try the homelink instructions I linked you to - looks like you got as far as step 5 - only steps 6,7,8 and 9 left. I'm 67 years old and I've been able to figure it out on 3 different 997's
Old Aug 1, 2011 | 05:07 PM
Now you a kicking a man why is already on the ground
Do we agree that "while keeping your fog lights in view" means that the fog lights needs be of switched off during this process?
Old Aug 1, 2011 | 05:12 PM
drive2006c4s's Avatar
drive2006c4s is infamous around these parts
I finally programmed my garage opener on my P. Thanks to you. I went to my car just now and tried. This is what I did and I followed the manual on page 156.
1. turn my engine on
2. i pressed and hold buttons #1 and #3 (about good 40 seconds) until light (next to button 1) flash quickly.
3. then, I press (&hold about 2 seconds) desired button which in my case it was button #2. the light (next to button 1) flash slowly.
4. then I took my garage door opener, went out and stand next to front bumper and press and HOLD (for me it took 5 seconds) the door opener UNTIL fog lights flash 3 times.
if you like to program one more button then go back to step number 3 above.
5. turn the engine off and take the key out.
6. you are done!
to test, engine must be "on" for the garage button to work.
Good Luck!
Old Aug 1, 2011 | 05:13 PM
Ballgie's Avatar
I will try homelink instructions tonight.
Old Aug 1, 2011 | 05:17 PM
jhbrennan's Avatar
It takes patience - if you got the foglights to flash 3x they you completed the most difficult step. Don't turn on the fog lights - the flashing just indicates you successfully completed that step. You don't need to start the engine either...but the ignition does need to be on. After you complete the "learn" step you may have to push your Homelink button a third time to get it to work - make sure the car isn't under the door.
After fog light flashes 3 times, I turned the engine off and removed the key.
i don't know if that makes a difference but it worked for me. I just did it now.
