Help - Clutch work on a 2006 911
Hello, need some advice: Indy quoting $2,700 for following:
Replace clutch - standard Sachs kit
Replace RMS
New Oil Filter, top of oil
Replace crank, flywheel seal
Replace clutch slave cylinder
Replace clutch release arm
Replace clutch actuating Fork
Replace clutch pushrod seal
Replace pilot bearing
Replace pivot ball pin
Flywheel bolts
All labor included to perform above, plus swapping axles left to right and vice versa.
9 hours of labor quoted for all clutch work.
Any opinions would be appreciated.
Thank you.
Replace RMS
Flywheel bolts
Thank you.
I just had my clutch, flywheel and RMS replaced at dealership on Long Island. Along with oil change ($340), brake fluid flush/replace (~$250) and new wiper blades the total came out to $5,575. If the guy is reputable, I would take the $2,700 and run!
The flywheel alone was listed as $1,500 for the part.
I also live in MI and used an Indy. Contact me for the detail if you wish.
Porsche of Huntington.
That is where I bought the car. The service guy seemed genuinely unhappy about having to replace the flywheel too.
I cant find one decent dealer called freeport roslyn ect all gave me a run around or a pricky attitude about warrenty work. Its amazing i buy 100k car and spend another 4k on warrenty. And im stuck here with a coolent leak
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
GrantRR
Jun 28, 2018 03:33 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
SharkyShark20
Sep 19, 2015 09:54 PM
