DIY Dectane Module Installation
Old Mar 25, 2012 | 04:13 AM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Ok, finally got around to installing the Dectane Module. Took some pix to give some members out there who are more visually oriented, an idea of how I went about in installing it.
Remove the Battery Access Panel
Remove the Rubber Seal around the trunk
Locate the 8 screws that hold the panel that houses the Multidisc CD Player or Nav Unit and remove them with a Phillip Screwdriver. Remove the panel thereafter.
Locate and pull out the tabs that hold the carpeting on both sides. I find that the easiest way to do this is turn the tab to vertical and slide my hand behind the carpeting and push out the tab with the carpeting.
Size:  270.2 KB Name:  P1000248-1.JPG
You should now have something that looks like this
Old Mar 25, 2012 | 04:39 AM
808c2s's Avatar
Next, you'll notice a triangular piece of plastic where I use to attach the Dectane Module with the provided sticky pad. Remove this piece with a Hex screwdriver, removing the 2 screws holding the piece to the wall behind it.
After removal of the triangular plastic piece, you will find a large and small circular rubber grommet separating the 2 compartments. Pull out the smaller grommet and thread the Positive and Negative wires through the hole and into the battery compartment area. Make a slit in the grommet to allow the wires to go through when the grommet is replaced back in the hole. It should look like this: Note: The Fuse Holder connected to the (+) wire will fit through the hole if you twist the cap off. This will separate it into 2 pieces. The bottom piece will go through the hole with ease. The top piece,will just be brought over and reattach to the bottom piece again.
Now, turn your attention to routing of the wires to the holes near the headlights as shown. Look at the pix showing the Module to get an idea of how you can route the wires. Thread the wires through this hole on both sides and you will see them coming through and reaching the front LED compartment areas as shown. Remember, before doing this, you should have already spliced additional wires to the Black & Red wires, as well as the Orange wire to allow them to reach the front LEDs.
Size:  349.1 KB Name:  P1000259-1.JPG
Follow TT2911 instructions for tapping the wirings.
After this, connect the (+) and (-) wires to the battery. Put everything back and enjoy your DRL functions.
Old Mar 25, 2012 | 06:55 AM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
rep 4 u...great post
Old Mar 25, 2012 | 08:57 AM
997pinoy911's Avatar
997pinoy911 is a jewel in the rough997pinoy911 is a jewel in the rough997pinoy911 is a jewel in the rough997pinoy911 is a jewel in the rough
Great write up! Thanks for taking the time! My order from Frank is coming this week, I was planning to do the upkinpol hack and sell the module, but now with pictures... I may as well do the harder way! Thanks!
Old Mar 26, 2012 | 04:55 AM
Vincent997S's Avatar
Vincent997S is infamous around these parts
Thanks a lot for the pics. That's what i expected.
But wich module do you use, the Dectane module are : TFLM-01 / TFLM-02 or TFLM-03 ?
Vincent.
Old Mar 26, 2012 | 11:22 AM
808c2s's Avatar
I got the TFLM-03, just like TT2911.
Vincent.
Old Mar 26, 2012 | 01:19 PM
Ok thx
Old Aug 7, 2015 | 04:32 PM
9114SX51's Avatar
9114SX51 is infamous around these parts
Hi All,
I just bought the Dectane DRL module.
I was wondering how you pass the cables from the module to the light in the front bumper ?
Any advise and/or pics ?
Thanks beforehand
Old Aug 15, 2015 | 01:17 PM
9114SX51's Avatar
Hi All,
How to remove the center pieces in the trunk as per below picture ?
Thx
Old Aug 16, 2015 | 09:05 PM
gadgetman's Avatar
gadgetman is a splendid one to beholdgadgetman is a splendid one to beholdgadgetman is a splendid one to beholdgadgetman is a splendid one to beholdgadgetman is a splendid one to beholdgadgetman is a splendid one to beholdgadgetman is a splendid one to behold
Originally Posted by 9114SX51
Hi All,
Thx
Slide it to the the right to remove it.
Old Aug 17, 2015 | 03:06 PM
9114SX51's Avatar
Thanks 😀
Money2536
Jan 19, 2022 08:22 AM
Mark @ AIM Performance
119
Jul 28, 2021 08:07 AM
MadWhip
Sep 3, 2015 02:04 PM
saline
Aug 19, 2015 12:25 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
