check engine visit workshop
Old May 6, 2012 | 11:38 AM
rocket911's Avatar
rocket911 is infamous around these parts
Hopefully someone knows... This morning I was driving my 997.2 for about a half hour and then shut the car off. Ten minutes later, restarted, drove for 2 blocks reving about 6k and then the "Check Engine Visit Workshop" display came on, along with a non flashing yellow icon.
Any insight on this? Any info on this would be greatly appreciated.
Old May 6, 2012 | 03:45 PM
Michaelwww's Avatar
Michaelwww is a jewel in the roughMichaelwww is a jewel in the roughMichaelwww is a jewel in the rough
Go to autozone and buy a code reader or have them read it. You can get one for $40 . I will take a random shot an o2 sensor is having issues. Post the code when you get it.
Old May 6, 2012 | 07:40 PM
zer0-60's Avatar
zer0-60 is a jewel in the roughzer0-60 is a jewel in the roughzer0-60 is a jewel in the rough
I had a similar experience when my ignition coils were cracked.. Dealer replaced under CPO warranty. Less than a week later it threw the same message, apparently misfiring.. they flashed the ECU and since then the problem has been solved.
Old May 7, 2012 | 11:06 AM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
Old May 8, 2012 | 11:34 AM
rocket911's Avatar
Just came from dealer. bad fuel cap gasket... go figure! Everything OK now. It should say check fuel cap so we don"t panic when we see check engine.
Old May 8, 2012 | 12:59 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
There is probably a lot of error codes that show up as 'System Fault Visit Workshop'. The 'Front Control Unit' being one. It's sort of the 'catch-all' display for miscellaneous faults or errors. I say as long as the message isn't linked to a significant condition or observation (ie. over temp oil or water, oil pressure, pools of liquid under the motor, etc) it shouldn't be considered catastrophic in nature.
Old May 8, 2012 | 01:28 PM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
if you'd like, you can come by my shop located on Staten Island I dont mind taking a look at it for you, no charge. I have the ability to scan for codes and read them out.
Old May 8, 2012 | 09:03 PM
Michaelwww's Avatar
Wow, totally missed the obvious one. I three click my gas cap to be sure.
Old May 9, 2012 | 07:36 PM
frontside720's Avatar
frontside720 is infamous around these partsfrontside720 is infamous around these parts
I had the same issue.
Gas Cap = Flashing Check Engine Warning
Thanks for the stress!!
Old May 10, 2012 | 08:52 AM
na011's Avatar
na011 is just really nicena011 is just really nicena011 is just really nicena011 is just really nicena011 is just really nice
The most current version/part number of the gas cap ends in .03. That is what I have an .03 on mine with a manufacture date of 10-2005. I wonder if any updated part is on the way or just treat it a "wear" part & replace every 4-5 years. We all know rubber "O" rings can't last forever.
Old May 10, 2012 | 11:21 AM
rocket911's Avatar
I agree, however my car is 2 1/2 years old with 6K. I have only filled it up w/gas 20 or 25 times. Doesn't make sense. Anyway I'm happy the problem was resolved w/ no major issues!
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
