Clutch Noise
Old Jun 23, 2012 | 07:01 AM
Malexgcab's Avatar
Malexgcab is infamous around these partsMalexgcab is infamous around these parts
Clutch Noise
I have noticed a noise from the engine compartment that sounds similar to a failing "fan/power steering belt". The sound occurs after depressing the clutch and occurs on 1st gear from a complete stop. I was able to reproduce the sound by starting the car on 2nd gear and the sound was definitely more pronounced/loud.
I mentioned it to the dealership and according to the SA, it might be that the clutch is glazed and I need to "scuff it" by doing hard launches.
I have been driving manual tranny for so long but I have not had that issue before. Not sure if I should trust SA's advice. Does it sound right?
Thanks.
Old Jun 23, 2012 | 06:42 PM
sizquik's Avatar
sizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond repute
Yep. It could be a glazed clutch or bad throwout bearing. It's easy to glaze your clutch if you drive in alot of stop-and-go traffic or slip it too much. I've had a few performance cars before and this is the first car that's made that noise. A nice, spirited drive is in order for you.
Old Jun 23, 2012 | 10:25 PM
Malexgcab's Avatar
Is a throw out bearing covered under cpo?
Spirited driving? As in hard launches? PSM off during drive?
Thanks in advance
Old Jun 24, 2012 | 01:01 PM
sizquik's Avatar
Just try driving the car aggressively for a bit. Hard accelerations, shifts, downshifts etc. PSM never off on the street!
Old Jun 24, 2012 | 01:30 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
it can t hurt to check your clutch/brake fluid level.... I don t think that s it but you didn t mention what year it is also.
Old Jun 24, 2012 | 07:43 PM
Malexgcab's Avatar
08 C2 with 22k miles. Still under CPO.
Bmanny
Sep 16, 2015 08:29 AM
Yogi911
Sep 9, 2015 08:20 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
andbos
Sep 7, 2015 07:13 PM
Saint Ari
Sep 4, 2015 03:30 PM
