2 washers installed on drain plug for oil change?
Old Aug 21, 2012 | 11:31 PM
wolfnards's Avatar
wolfnards has a spectacular aura aboutwolfnards has a spectacular aura about
Thanks for the DIY posts on this forum, I changed oil for the first time ever on my 997.2 today. Ordered 2 sets each of the oil filters and drain plugs from Suncoast. The drain plugs came with 4 washers (for 2 sets), so i installed 2 washers on the drain plug.
Is this incorrect? if so, should I remove/replace the drain plug with 1 washer and refill any oil i lose? that seems like a mess, but i should probably do the right thing. thanks in advance.
Old Aug 21, 2012 | 11:43 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
I don't think you will have an issue with 2 washers. You will still have plenty of thread engagement. I would keep an eye on it for any signs of dripping oil but I doubt you will see any. Next time just use one.
Old Aug 21, 2012 | 11:53 PM
wolfnards's Avatar
Thanks as always, Alan!
Old Aug 22, 2012 | 06:57 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
The second washer is for the next oil change. Reuse the plug, swap the washer.
No worries now - leave both on as long as you have no leaking. But next time use one and save one for later.
Old Aug 22, 2012 | 07:50 AM
wolfnards's Avatar
thanks for the reassurance, folks!
Old Aug 22, 2012 | 09:11 AM
JB in AR's Avatar
JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !
Washers are cheap, and they probably did this because some folks (like me ) choose to change their oil more frequently than called for in the maintenance interval recommended by Porsche, and they swap out the filter every OTHER oil change. Therefore, someone on this schedule would be needing twice as many washers.
That's my story and I'm sticking with it...
Old Aug 22, 2012 | 10:27 AM
thrashek's Avatar
thrashek is a name known to allthrashek is a name known to allthrashek is a name known to allthrashek is a name known to allthrashek is a name known to allthrashek is a name known to all
While the 997.2 cars don't have some of the same issues as 997.1 cars, I still recommend you get the LN Engineering Magnetic Drain Plug. Plenty of good reasons, and a great preventative measure for long-term owners.
Old Aug 22, 2012 | 11:14 AM
JB in AR's Avatar
Great recommendation. I just went on-line and ordered one myself because it makes sense. Thanks!
COBB Tuning
Jan 1, 2025 09:02 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
00aston
Aug 27, 2015 12:01 AM
Lucid Moment
Aug 20, 2015 02:22 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
