Dension Gateway 500s BT Contacts problem
Old Sep 17, 2012 | 03:16 PM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
As the title says, i cannot get my contacts to show up on the PCM... this means i also cannot answer calls or dial out form the pcm.
The screen reads "Insert valid sim card" and all other options on the right are greyed out, as if nothing is connected.
On the flip side, the BT phone feature works and goes through the car speakers ONLY if i call out from my cell phone.... Any ideas?
My phone is a Balackberry 9900, i have never had a problem with this phone in regards to connecting hands-free, contacts, etc.
Old Sep 17, 2012 | 06:08 PM
amoahkuc's Avatar
amoahkuc is infamous around these parts
I have read reviews and don't know if this is related or not that if you have a lot of contacts that it can take a long time (10-15 minutes) for all your contacts to sync to the PCM and it has to do it every time you disconnect and reconnect.
Old Sep 18, 2012 | 01:44 AM
johnnyb2016's Avatar
johnnyb2016 is infamous around these parts
I have fitted one of thses ot my 2005 997 and initially only had 10 contacts appear on the screen.
To get all of them to appear you need to unplug and bridge the telephone MOST unit under the drivers seat.
Old Sep 18, 2012 | 07:23 AM
mikestyle's Avatar
Interesting... can anyone expand on this?
Old Sep 18, 2012 | 07:43 AM
I states in section 6 (Phone) of the fitting isntructions, that if the Dension unit is to be used for the phone option the original unit should be removed from the MOST ring.
http://www.dension.com/sites/default...tall_guide.pdf
Old Sep 18, 2012 | 01:29 PM
mikestyle's Avatar
Thanks Johnny!
Informed the installer of the issue, he looked into it right away and fixed the problem.... it was exactly as you say the optional phone needed to be disconnected from the "loop"
Thanks again!
Old Sep 20, 2012 | 03:21 PM
Tito_gsx's Avatar
Tito_gsx is infamous around these parts
My Dension has the same phone issue. Can anyone tell me where the phone loop is? I presume its the fiber optic cable, but where do I find it?
Old Sep 20, 2012 | 03:27 PM
It's under the drivers seat on my car, RHD, so probably under your passenger seat.
Should be a black plug with two orange "wires" going into it.
You'll need a fibre optic bridge to loop the MOST network.
Should you have trouble, they are available from BMW dealerships. Don't have the part number to hand, but can look it up if you need it.
Old Sep 20, 2012 | 03:34 PM
FYI:
BMW part number: 61 13 6 931 507
Old Sep 26, 2012 | 01:39 PM
Tito_gsx's Avatar
Thanks I'll give it a try
Sep 14, 2015 06:42 PM
pilotscottb
Sep 1, 2015 10:29 PM
gulf gt
Aug 27, 2015 10:27 AM
OldBoldPilot
Aug 26, 2015 01:12 PM
