Engine noise - please help diagnose (Video)
Old Nov 28, 2012 | 10:08 AM
ad3998's Avatar
ad3998 is infamous around these parts
Sorry for another "engine noise" post. I searched but didn't find anything close to what I'm experiencing. It's a high pitched whistling sound that you can hear at idle and it's consistent. Just started yesterday. I have 28k miles '09 c2s. I've included a video as reference. Would appreciate it if anyone has any ideas or experienced a similar issue. TIA.
Old Nov 28, 2012 | 11:00 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Any change buy pushing in the clutch? Throw out bearing.
Could be a loose plug too.
Old Nov 28, 2012 | 11:07 AM
ad3998's Avatar
I forgot to mention, it's PDK and not manual. Just started her up this morning and now the noise is not evident....but car is not warmed up. I"m guessing the noise may occur only during and after car has been driven.
Old Nov 28, 2012 | 12:22 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
Accessory belt or idler pulley?
Old Nov 28, 2012 | 01:28 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
From the sounds of it, it is a mechanical rubbing/rotation source.
If it were from a leaky valve or hose, it would be consistent, and if it were related to a cylinder in some way it would be in sync with the engine firing. This off and on, sounds like a rotating piece traveling or wobbling a bit and when it gets to a certain point it whines a bit and maybe changes direction for a bit, then wanders back.
Old Nov 28, 2012 | 02:11 PM
ad3998's Avatar
Thanks everyone for your feedback.
And Minok, some good insight.
I'll drive it more over the weekend and see if the sound persists. I'd like to be able to take it to the dealership knowing this whine will be duplicated at the time of my visit.
Old Nov 28, 2012 | 02:56 PM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
my vote is for a pulley (w-pump)?
Old Nov 28, 2012 | 03:44 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
Wy drive it around? If something isn't right... Take it in and have it looked at and or fixed. It could be a warning sign.
Old Nov 28, 2012 | 05:14 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Do you know how to take a long screwdriver or similar and use it as a stethoscope and place it on certain non moving parts(handle side to ear) to isolate the sound... Maybe like was stated a bearing on the alternator or similar. Be careful as there are moving parts!!!
Old Nov 28, 2012 | 05:29 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
As Hella.... suggested , get it to the dealer, via flatbed tow truck, and have the dealer diagnose it. Driving it around could be a very costly mistake if it's an internal engine issue.
Old Apr 30, 2013 | 01:35 PM
mattjtaylor50's Avatar
mattjtaylor50 is infamous around these parts
did you ever find out what this was? my 997.2 pdk is making the same noise at idle (noticed after long drive). not always present
thanks
Old May 4, 2013 | 11:29 AM
ad3998's Avatar
Yes, tech found it was a crack in the purge line valve which they replaced and all is good. Let me know what your tech finds the issue to be...would like to hear if it's consistent.
Old May 4, 2013 | 04:08 PM
911Stud's Avatar
911Stud is infamous around these parts
Crack in the purge line valve? What exactly is this?
tzeseong
Aug 17, 2024 11:08 AM
turbotuner20v
Sep 11, 2015 12:02 PM
mlife2878
Aug 26, 2015 07:02 PM
Zero911
Aug 24, 2015 06:51 PM
