Wheel spacers stuck to rear wheels
Old Apr 10, 2013 | 09:38 AM
wolfnards's Avatar
wolfnards has a spectacular aura aboutwolfnards has a spectacular aura about
Hi folks,
installed the RSS spacers from Suncoast before mounting my winter wheels/tires (see thread https://www.6speedonline.com/forums/...questions.html)
I attempted to switch to summer wheels/tires and do a brake fluid flush. The front spacers were not hub-centric, so that came out just fine. However, the rear spacers are hub-centric and are "stuck" to the wheel. there are no mount points to try and gently pry it out. I tried using a plastic wedge and rubber mallet to bang and loosen it to no avail.
I've seen some suggestions about WD40, but wouldn't that be a terrible idea in case some of it transfers from the spacers to the brakes (I guess need to thoroughly wash it off)?
Advice kindly appreciated
Best,
wolf
Old Apr 10, 2013 | 12:00 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
You might try a little heat and/or give them a solid whack w/ a hammer. They're solid aluminum so they're pretty immune to damage from a solid hammer strike.
Old Apr 10, 2013 | 12:40 PM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
Aluminum can dent as its softer than steel.
Put a block of wood against the spacer and give a good whack with the hammer.
Old Apr 10, 2013 | 12:56 PM
Burg Boxster's Avatar
Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !
Try some PB blaster too - let it soak for a bit and it should release. Just make sure to clean the rotors/pads liberally afterwards w/ brake cleaner. Then once freed up, make sure you apply anti-seize to the rotor hat/hub mating surface and/or back of wheel in future (and on spacers) to prevent or at least limit amount of corrosion.
Good luck
Old Apr 10, 2013 | 11:01 PM
NorthVan's Avatar
I have used a flat head screw driver and a hammer. Wedge the screw driver in between the spacer and the rotor and give it a few hits. When you remount them apply a little grease to keep it from happening again.
Old Apr 10, 2013 | 11:37 PM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
This happened to mine as well. There should be a slight gap at some point along the seam where they join. You can then pry them apart.
Old Apr 11, 2013 | 10:19 AM
C4Sbeebe's Avatar
C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !C4Sbeebe Is a GOD !
is the spacer stuck to the rotor or the wheel? OP said 'wheel'. i have also had spacers get stuck on wheels.
Old Apr 11, 2013 | 10:57 AM
jhbrennan's Avatar
You mean hub, not rotor. It would be a real problem if stuck to the rotor.
Old Apr 13, 2013 | 06:25 AM
wolfnards's Avatar
you are correct - stuck to the wheel and no gaps on the OZ Ultraleggera
Old Apr 13, 2013 | 06:29 AM
wolfnards's Avatar
Thanks everyone for the feedback! I did a combination of the techniques provided: The hammer definitely made a dent and I tried prying it off and there definitely is a deep scratch on the inside of the spacer where it meets wheel hub - will this be an issue?
in any case, I had to remove the wheel cap to get the right leverage that way, used some PB Blaster, found a piece of wood and used the mallet to bang it out. Worked like a charm.
This forum is full of geniuses. Thanks, everyone.
wolf
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
