Got myself an X51 air box, GT3 throttle body, plenum, before & after dynos
Old Jun 11, 2013 | 04:52 PM
  #136
Gibbo205's Avatar
Gibbo205 is a jewel in the roughGibbo205 is a jewel in the roughGibbo205 is a jewel in the rough
Hi there
Ok managed to get a custom silicone hose so I can use my stock Airbox with larger throttle body and plenum.
So hopefully this weekend I can dyno the following:-
1. Softronic tune with larger tb / plenum with stock Airbox with BMC filter and resonator removed for max airflow.
2. X51 revised Softronic tune with larger tb / plenum with X51 Airbox with BMC filters.
I've done some race logic testing:-
0-62 (2nd gear) 2.9s with stock Airbox, 2.8s with X51 Airbox.
50-95 (2nd-3rd gear) 5.8s with stock Airbox, 5.5s with X51 Airbox.
60-110 (2nd, 3rd & 4th gear) 8.2s with stock Airbox, 7.5s with X51 Airbox.
60-110 (4th gear) 9s flat for both air boxes.
To drive, the stock Airbox with softronic tune feels to have more torque and smoother sub 3200rpm, throttle feels better, hard to explain, not response just better, no doubt because of the vario ram system helping with low-end torque. Nothing else is better though.
The X51 Airbox with revised X51 tune is just a responsive now, even more so at higher RPM's, the cars seems to pull harder 3500rpm upwards and even more so beyond 5500rpm. The noise/soundtrack is vastly better.
The on the road test show car accelerates faster when using gears, but as the 60-110 run in 4th shows a little low-down power/torque is lost, marginal but would be nice to get them back.
Maybe Scott can revise the X51 tune to also make use of vario ram so get best of both worlds.
Shall get the dyno to compare / overlap both runs so we can see how the air boxes and tunes effect the power runs, shall also video the runs to record AFR data.
Is the air box worth while? Yes just for the noise and the way the car pulls at higher rpms
Old Jun 14, 2013 | 05:05 PM
  #137
Happy911S's Avatar
Happy911S is infamous around these parts
I must be missing something. You indicated that you are doing 0 to 62 in less than 3 seconds. Are you sure of this?
Old Jun 16, 2013 | 02:42 AM
  #138
Gibbo205's Avatar
That should be 30-62
Old Jun 17, 2013 | 08:50 PM
  #139
Mr.997's Avatar
Mr.997 is infamous around these partsMr.997 is infamous around these parts
Wow! Well that's a lot of info to take in. I have a 997.1 s and I'm running a Fabspeed x-pipe with the gunto hack, Bmc filter and evomit tune. On a Dynojet I put down 306rwhp at 6500 rpm with 285rwtq. I'm mad that I didn't get a base line first. I don't know if that's good?
Old Jun 20, 2013 | 10:36 PM
  #140
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
you need performance cats to really feel gains - trust me they make a big difference
i had also stated earlier if you do cats save up for headers.. the increased air flor makes the exhaust note very high pitched and really sounds terrible. i found the only cure was aftermarket equal length headers.. AWE tuning makes them.
Old Jun 21, 2013 | 04:28 PM
  #141
Mr.997's Avatar
I have no cats.
Old Jul 12, 2013 | 01:27 AM
  #142
qikqbn's Avatar
qikqbn has much to be proud ofqikqbn has much to be proud ofqikqbn has much to be proud ofqikqbn has much to be proud ofqikqbn has much to be proud ofqikqbn has much to be proud ofqikqbn has much to be proud ofqikqbn has much to be proud ofqikqbn has much to be proud of
wanted to subscribe...
I experienced the exact same air fuel ratio problems when I did an upgraded engine conversion on a boxster many years ago. I had upgraded the ecu fuel maps to the larger engine but kept the old/smaller maf housing on. I had the exact opposite happen to me. I was running super Rich, rather then very Lean.
So this thread is 100% accurate. The size of your Maf Housing and air flow readings are EXTREMELY important to the calculations used by the factory ecu fuel maps. The factory ECU fuel maps assume you are using the correct size maf housing which creates an assumed air flow speed at certain rpm's.
If you go to a larger diameter maf housing, like an X-51, from stock, then the airflow readings slow down... although airflow "volume" actually increases. The slower/lower voltage reading sent from the maf sensor to your ecu makes it believe you require LESS fuel which creates a LEAN situation in reality.
If you go to a smaller diameter maf housing the reverse happens. Airflow is crammed or rushed through the smaller diameter which then sends a stronger voltage signal to the ecu and calls for more fuel, even though air intake volume is decreased... this creates a RICH fuel situation.
Proper tuning is important, so working with a ecu tuner directly is great. but lots of back and forth when problems arise. I actually solved my issues by using an after market mass air flow tuning computer and air fuel ratio gauge. I used an Apexi unit that allows me to adjust the maf signal every 500 rpms. so I can have the exact air fuel ratio needed every 500 rpms. On that particular project car the horsepower gains were 25-30 hp and 15-20 lbs of torque with proper fuel as compared to too rich or too lean situations.
So as the OP has suggested ... if you have upgraded your maf housing diameter without making the proper adjustments to the ecu parameters... then you may be harming your engine by running too lean too often. especially during the hot summer months. highly recommend you get those fuel maps sorted out.. your car will run WAY better.
Old Jul 14, 2013 | 07:39 PM
  #143
floatingkiwi's Avatar
floatingkiwi is infamous around these parts
Originally Posted by Jam996
Here is a part # for a 996 airbox flange, should fit a 997. I used it on a evo airbox for my 997 for the gap between lid and intake. 996 110 250 52 about 20$.
I think I'm in the same boat with a 997.1 C2s aerokit that has no seal in the lid so that the EVO intake doesn't seal on anything. So is this the part that fits into a "bare" decklid? I suspect whoever installed my EVO intake left this out/removed it for god only knows why.
turbotuner20v
Sep 11, 2015 12:02 PM
The Oss
Aug 24, 2015 08:19 PM
magoochi
Aug 23, 2015 05:54 PM
ECS Tuning - MB
Aug 21, 2015 02:25 PM
Vrseis
Aug 20, 2015 07:41 AM
