Adding engine oil void engine warranty?
Old Jun 25, 2013 | 10:33 AM
  #31
jhbrennan's Avatar
Originally Posted by oliverletz
Please don't try this at home!
Jet-A is very similar to diesel fuel, while regular gas is a whole different animal. Maybe you thought of 100LL aviation fuel for piston engines? They are color coded to make sure you get the right one at the pump or from the fuel truck ...
Cheers,
Oliver
Yeah...mixing gas ((even 100ll) with jet fuel is a recipe for a disaster especially if airborne.
Old Jun 25, 2013 | 10:44 AM
  #32
oliverletz's Avatar
oliverletz is infamous around these parts
Sorry, I wasn't clear ... I meant, he though maybe of replenishing 100LL with regular auto gas, which is possible, but still a very bad idea. Running an engine in thin air and very cold temperatures at rated power setting for long periods of time on even 93 octane fuel is going to get very expensive very quickly. Not even mentioning the book-full of regulations you would be breaking ...
Old Jun 25, 2013 | 11:53 AM
  #33
tiyyara's Avatar
tiyyara is infamous around these parts
Originally Posted by asianporsche
I read it but I miss interpreted it.... I thought every segement represents a portion of the total volume of the engine, that was very stupid. And I did drained all the oil and added the right amount of oil according to the manual, the car was fine after engine fans ran off couple of times, so far, no engine light come on. Is that gona void the warranty?
I think based on what you did they should void your warranty for lack of common sense
First thing you do if the "bar" is low, is add 1/2 a quart at most to see if the bar moves and how much. Especially if you never added oil to the car.
Adding 3 quarts to an engine that has oil (short of a caterpillar coal mover) at any point is too much.
You will be fine. You learned your lesson, I am sure most of us have done something silly like this at one point or another!
Old Jun 25, 2013 | 07:27 PM
  #34
sixgun95's Avatar
sixgun95 is infamous around these parts
Cheers,
Oliver
Correct, 100LL can be used to supplement Jet A in a pinch for turbine engines. Athough you really dont want to do this, its acceptable and can be used without a problem for 10 hrs before parts need to be replaced. Not every airport has Jet A, and if you need it, you need it...dont ask how I know poor fuel planning, crap wx, high winds...oh well!
Old Jun 25, 2013 | 07:43 PM
  #35
slammp's Avatar
slammp is infamous around these parts
My first car. A ford festiva. I think I was 18. 1st oil change ever, no one to teach me at the time. I drained the tranny and added 3.5 quarts of oil to the motor. Blew every seal on the engine. Oil everywhere. I drove 30 miles on the highway before I figured out that I could barely shift. Took it to jiffy lube and they set both the fluids at the proper level and charged me $15. Aside from having to steam clean the engine and 4th gear sounding like reverse for the rest of its life I never had another problem and it never leaked oil!
Lesson learned the hard way.
That was also the car I learned standard on.
Jul 29, 2019 11:13 AM
Sales@RSW
Sep 3, 2015 09:34 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
