RS engine mounts vs Suncoast RS style engine mounts for 997.1 C2S
Old May 25, 2014 | 10:03 PM
JBSPEED's Avatar
JBSPEED is infamous around these parts
Hi, anyone has these on can share their experiences? Are the 2 brands similar or even the same? Suncoast stated it's the genuine porsche part. I've never used RSS before so wondering how good it is compared with the genuine porsche part. Also is this mod worth the money?
thank you
Old May 25, 2014 | 10:18 PM
ogun228's Avatar
ogun228 is infamous around these parts
First what are you trying to achieve? Are the current ones giving you problems? If so, how old or worn are they?
You'd have to ask these questions and proceed accordingly. The car came with the parts and unless they have failed or not met your criteria why even consider a switch?
Old May 26, 2014 | 12:29 AM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
I have the Suncoast RS engine mounts. The RSS and Suncoast ones achieve the same results, but the RSS ones are nicer . My Suncoast RS came with 1 inch shorter bolts, thus, I had to find a longer bolt to secure them to the frame. A Panamera engine mount bolt did the trick.
In terms of performance, there is a difference. Car feels more solid in corners. There's no slushing of the back end in tight corners and long sweepers. You will have more NVH, as in hearing the engine more and feeling the vibration more in the steering wheel.
Is it worth it? Only you can decide that. In my case, it was and still is. I feel more connected to the car.
Old May 26, 2014 | 09:28 AM
JBSPEED's Avatar
Thank you. The RSS one does look nicer
Old May 27, 2014 | 12:36 PM
Phil_D's Avatar
Phil_D is infamous around these partsPhil_D is infamous around these parts
I have the RSS mounts. There is a definite improvement in overall feel and shifting is more precise. There is noticeably more NVH, but I kind of like it as it feels more "sporty". However, around 3000 RPM with light throttle there is quite a noticeable vibration, both feel and noise. It was actually making the rear license tag vibrate really loud, but some foam tape under the plate fixed that.
Old May 27, 2014 | 02:31 PM
ufreefer's Avatar
ufreefer is infamous around these parts
I recently installed the RSS mounts and love them. My feedback is exactly the same as "Phil D"
Old May 27, 2014 | 03:20 PM
808c2s's Avatar
Interesting that you guys have a vibration at 3000 rpm under light throttle. My does not...go figure.
Old May 29, 2014 | 08:41 PM
GixxerGino's Avatar
GixxerGino is a splendid one to beholdGixxerGino is a splendid one to beholdGixxerGino is a splendid one to beholdGixxerGino is a splendid one to beholdGixxerGino is a splendid one to beholdGixxerGino is a splendid one to behold
Question
This may sound dumb, but what do they do besides offer a direct feel from the motor?
Old May 29, 2014 | 10:38 PM
808c2s's Avatar
See mine and PhilD's responses above.
Old May 29, 2014 | 10:41 PM
GixxerGino's Avatar
Thumbs up
Ok, got it. thanks!
Prob going to wait till I have problems with mine.
Jul 29, 2019 11:13 AM
pwdrhound
Aug 23, 2015 07:36 PM
pwdrhound
Aug 20, 2015 05:54 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
