997.1 front fog light & trunk light not working
Old Jun 8, 2014 | 07:47 PM
RSW's Avatar
RSW
RSW is infamous around these parts
Light switch works with green fog light on. Rear fog works without problem. Fuse (C3) is not blown. Light bulbs are ok.
Anyone had this problem before? Thanks for sharing!
Old Jun 8, 2014 | 07:55 PM
Steve997S's Avatar
Steve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond repute
I had a frunk light not working in my 997.2. Luckily it was fixed under warranty as there's a controller switch which needed replacing, and it's located inside the front bumper. Would have cost quite a bit to replace.
Old Jun 9, 2014 | 12:39 AM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
Check our fuses?
Old Jun 9, 2014 | 02:07 PM
RSW's Avatar
RSW
No fuse for fog light, but the fuse for front end controller & light switch (C3) is fine without problem. Light bulbs are fine too. This is very strange.
Old Jun 9, 2014 | 02:39 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Check the red push thing on the fuse box and make sure it's fully depressed. A short may trigger it and you will lose power on the trunk's light area.
Old Jun 9, 2014 | 11:37 PM
RSW's Avatar
RSW
Checked that but not helpful. Could be front control unit problem but all other lights (hi/lo beam, side markers, rear fog, tail lights) are working except fog & trunk!
Old Oct 24, 2015 | 04:48 PM
forbes210's Avatar
forbes210 is infamous around these parts
I got the same issue. Dealer looked at it and said its a faulty light switch but when I swap the actual switch with my friend (he got identical car) the lights still didn't work and mine switch worked fine in his car. What's interesting that with durametic I was able to make the fog lights work. I head dealer replace from end control module some time ago. Maybe they missed some programming or something.
Old Dec 5, 2015 | 11:31 AM
RSW's Avatar
RSW
Problem fixed? Please share.
Old Dec 23, 2015 | 05:38 AM
CayenneS2083's Avatar
CayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really nice
I just had my front control module replaced and am now having this same problem. I think that the shop incorrectly programmed it but I went over there and we couldn't figure it out. Anyone ever find out the reason for this issue?
Old Feb 21, 2016 | 02:33 PM
RSW's Avatar
RSW
Did you go back and had it reprogrammed?
Old Apr 30, 2016 | 11:27 AM
RSW's Avatar
RSW
Fog light not working
Hello Forbes,
I have exactly the same problem. New switch didn't work but could make it work with software tool.
Did you go back to the dealer for programming?
Thanks for sharing.
Old May 10, 2016 | 08:57 AM
jsm996's Avatar
jsm996 is infamous around these parts
Fixed!
I had this same issue (on my 997) of the frunk light and fog lights not working, but had it resolved today at my local Porsche dealer. The front control module needed to be "reset" to talk to the rest of the car...said my service advisor. They were really great about it and only charged me 1/2hr labor. That, combined with the free car wash, came out to be much less than I expected.
I noticed this issue when I purchased the car, but didn't think too much of it. When I spoke to the previous owner, he mentioned he was polishing the headlights and the static charge fried the front control module. I believe he had the front control module replaced by his indy, but only "coded" with the durametric tool. When I first got the car home I tried reprograming/reset/coding the module (via durametric), but nothing worked. It appears you need the Porsche PIWIS software to do this.
Hope this helps.
Old May 10, 2016 | 06:18 PM
MkC2S's Avatar
good to know, thanks. I'll remove the headlights when/if I'm going to polish them.
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
