997.1 LED DRLs--Working well?
Old Dec 13, 2014 | 08:30 PM
martidamm's Avatar
martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !martidamm Is a GOD !
Originally Posted by Miami4me
Actually, to prevent battery drain, you will need to install a diode, between positions 2 and 5 on the wiring bus in the headlight switch. Do a search on 6speed for $2 DRL solutions. It's easy and works well.
you are correct, not resistor...... Diode.
Old Dec 14, 2014 | 04:57 PM
Gary B's Avatar
Gary B has a spectacular aura aboutGary B has a spectacular aura about
Originally Posted by TCZ
I am considering doing the DRL upgrade from Del-Ray Customs. Just wondering if those that have had them installed for a while are still happy with them? I have this fear of having them for a year and then a bulb going out and being out a whack of cash........ Thx
That is just what happened to me. After about 14 months and less than 5,000 miles my passenger DRL went out, fog lights still work, but still upsetting. I will switch back to my stock lights soon. Save your cash my friend.
Sent from my iPad using 6SpeedOnline
Old Dec 14, 2014 | 05:52 PM
BigZ's Avatar
BigZ is infamous around these parts
What ever happened to leds lasting forever?
Old Dec 14, 2014 | 06:33 PM
TCZ's Avatar
TCZ
TCZ is infamous around these parts
Thanks. I have always found individual LEDs bulbs to be very finicky. That's why the larger units/housings scare me in terms of reliability over the long haul....
Old Dec 14, 2014 | 06:55 PM
Miami4me's Avatar
Miami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud of
That is just what happened to me. After about 14 months and less than 5,000 miles my passenger DRL went out, fog lights still work, but still upsetting. I will switch back to my stock lights soon. Save your cash my friend. Sent from my iPad using 6SpeedOnline
Respectfully, that's where I disagree. Even though I've had a number of LED failures, the look is so much better than OEM that it's still very much worth the hassle. The ones I've had that have failed have done so fairly quickly, and were usually replaced under warranty. To me, the only question is whether you really get better quality if you pay more for the product. My personal experience is that you do not, and that it's hit or miss. I've had inexpensive ones work flawlessly, and branded ones that have failed right away.
I don't think there are very many Taiwanese companies that manufacture these lights. Generally, the lights themselves work fine, but there are connection or electrical resistance issues that can register errors. I've never had an LED bulb fail. Some of these errors, once identified, can be easily fixed. Overall, the light fixtures are extremely easy for a non-mechanical guy like me to swap out, so there are no associated labor charges. If one fails after the warranty expires, the issue is whether it's worth another $1-300 to do it again. For me, it's an easy call. I don't mind spending money, but I can't stand wasting it. LEDs just look so much better than stock that's I think it's worth it, but it's a pure judgment call.
My very first light swap were a set of used smoked taillights I found on eBay. For $65, I didn't expect much, and I stuck my toe in the water to try them. I was hooked. They lasted almost a year. By then, I knew what I wanted, and paid $350 for new ones. They've been trouble free for many months. I suggest you consider an inexpensive "trial" set. Be careful, though. It is addictive.
Old Dec 15, 2014 | 08:29 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Walter,
So on the average, based on your experience, how long do the front last? How about the rear ones?
Thanks.
Old Dec 15, 2014 | 08:30 AM
martidamm's Avatar
Originally Posted by cab83_750
Walter, So on the average, based on your experience, how long do the front last? How about the rear ones? Thanks.
2 years here no issues...
Old Dec 15, 2014 | 08:35 AM
cab83_750's Avatar
Congrats. How many miles on the rear lights in 2 years? And what brand are they?
I don't think we have enough data points, but so far it appears to be that (except for you) these lights don't last as long as they should.
Old Dec 15, 2014 | 08:36 AM
martidamm's Avatar
Congrats. How many miles on the rear lights in 2 years? And what brand are they? I don't think we have enough data points, but so far it appears to be that (except for you) these lights don't last as long as they should.
about 7k, I live in Chicago so only use it in the warm months ....dectanes
Old Dec 15, 2014 | 08:47 AM
cab83_750's Avatar
So this translates to about 7 months worth of use 2-year ownership. I was hoping you would say 24,000 miles.
Mine is a daily driver and that was why I had to ask the question.
Thanks.
Windsor
Old Dec 15, 2014 | 10:43 AM
Miami4me's Avatar
Both front and rear have been working trouble free for about a year now, 10K mikes as a DD. MY most problematic lights, by far, were the LED side markers. The double tube ones kept failing. I went with a set that has a series of LED bulbs, and they've been completely trouble free. My only ongoing issue is a rear fog light error message. It's probably an easy fix for someone who knows what they're doing.
Old Dec 16, 2014 | 10:10 AM
stavros's Avatar
stavros is infamous around these parts
Great conversation and feedback. I've done my fog/drl with LED and now need to deal with the taillights and have been concerned about the cost. I think I'll end up going with Dectanes just for piece of mind and warranty/service, if necessary.
Old Dec 16, 2014 | 11:27 AM
CPD1216's Avatar
CPD1216 is infamous around these parts
Has anyone heard of the Spyder taillight LED's for these cars? Any feedback on them? They're going for under $400.
NRoy7
Jul 4, 2022 04:03 AM
NRoy7
Sep 19, 2015 06:59 AM
nick-seattle
Sep 18, 2015 08:14 AM
ECS Tuning - VW
Sep 11, 2015 01:17 PM
ECS Tuning - VW
Sep 9, 2015 12:35 PM
