Intermitten ignition issue
Old Apr 16, 2015 | 07:12 PM
grnmchn's Avatar
grnmchn is infamous around these parts
2007 Carrera S Cabrio.
Sometimes, when I insert the key, the car just does...nothing.
Normally, the radio and the airbag light comes on, but every once in a while I get nothing.
New battery and wiring, so thats not the problem.
Any ideas out there??
Old Apr 16, 2015 | 07:32 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Does it make a clicking sound? If you pull the key out and reinsert, does the engine start? Have you tried shaking the key while trying to start the engine?
Old Apr 16, 2015 | 07:51 PM
grnmchn's Avatar
When it happens, there is no click. If I keep inserting the key, eventually it does click and start.
It only happens once in a while and it happens with both of my keys.
Old Apr 16, 2015 | 08:53 PM
cab83_750's Avatar
I would start with replacing the ignition switch. That probably would be the cheapest and quickest step without going through a bunch of electrical troubleshooting (starter, solenoid, etc.).
If it's not the switch, you can always keep the switch as you'll eventually need it.
How many miles? Do you have a heavy key chain?
Old Apr 16, 2015 | 08:54 PM
cab83_750's Avatar
Oops! You said new wiring. What "wiring" is new?
Old Apr 17, 2015 | 09:47 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
i would say ig switch or even more stupid - maybe the key? if batt is dead or chip inside is fried, i've seen others report starting issues.
Old Apr 17, 2015 | 09:52 AM
cab83_750's Avatar
I was thinking about the batteries also but he said "both keys" do the same thing. Though remote, still possible.
Old Apr 17, 2015 | 11:02 AM
grnmchn's Avatar
Thanks for the replies.
The battery is brand new. One of the keys is brand new.
The wiring replaced was 6 ignition coils.
Last year I thought one of the dealer techs was talking about replacing the ignition - something behind where you stick the key into...not sure what he meant, but it sounded expensive.
Old Apr 17, 2015 | 05:45 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
One of the most common electrical items to fail on some of the older Porsche's is the ignition switch. This failure can show up in any number of ways. The car can refuse to start some of the time, the key may not turn too easily in the ignition, or strange electrical problems may appear. Read more about the issue and a DIY fix here at this Tech Article.
We also have ignition switches available on our parts catalog here.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Apr 18, 2015 | 12:07 AM
cab83_750's Avatar
The tech and what I mentioned is the same thing. And yes, it's the one behind where you stick your key in.
I see that PelicanParts also responded. Give them a call and ask how much. I am a long customer of PP but not affiliated.
Old Apr 18, 2015 | 08:37 AM
grnmchn's Avatar
OK, I'll try the ig switch and hope for the best.
Thanks guys.
Old Apr 18, 2015 | 02:51 PM
cab83_750's Avatar
Electrical issues, especially when intermittent, seem to be the worst to diagnose and fix. Let's hope it is the switch.
Old Apr 18, 2015 | 07:42 PM
sc235813's Avatar
sc235813 is infamous around these parts
is it m6?
had same problem with my 997.2 c4s m6. problem was the clutch switch (don't know what it's really called). sometimes, re-engaging the clutch enabled start, but often no. they replaced the button that gets tripped when the clutch is depressed and the problem went away.
good luck.
-sam
Old Apr 24, 2015 | 02:54 PM
grnmchn's Avatar
I did receive this ignition switch, thank you.
I wont need to change my key for this replacement, will I??
Old Apr 25, 2015 | 12:20 PM
GS997S's Avatar
GS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond repute
good luck.
-sam
I had the same issue with my 2012 997 GTS. Failure of this ignition interlock switch is common.
