Interesting problem occured today.
Old Jun 10, 2007 | 10:09 PM
500's Avatar
500
500 is infamous around these parts500 is infamous around these parts
Question Interesting problem occured today.
I dropped my car (07 997S 2900 miles) off at the dealership on Friday afternoon so they could finally address my brake squealing problem (which they did). When I picked up the car today and as I began to pull out of the service area the engine sputtered a little bit as I was slowly pulling away; I didn't think too much about it but knew I'd never had this happen before. We then went shopping at the mall for about 2 hrs and when I went to drive away the exact same thing occured when I was backing out of the parking space. I would best describe this a the engine sputtered/hesitated a few times as I increased the rpms slighlty to begin backing out (with the clutch dpressed) and again as I gave it some rpms to pull away. The car seems to clear itself of this malady after about 30 seconds of the engine running and it only seem to occur when the engine is warm, not hot or fully cold. Anyone have any experiance with this? Any thoughts would be most welcome.
Thanks.
Old Jun 11, 2007 | 07:06 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Mine does this from time to time. Dealer can not recreate this problem and there are no codes for them to look at. According to the dealer if there are no codes thrown there is nothing wrong with the engine or if they can not re-create the hesitation.
Old Jun 11, 2007 | 06:47 PM
wbellinz's Avatar
wbellinz is infamous around these parts
Try a different brand of gas.
Old Jun 11, 2007 | 06:51 PM
wizo's Avatar
wizo is infamous around these parts
Try that or I would disconnect your batter(neg) and then let it be for about 5min. Then reconnect. That might reset any Ecu setting unwanted and might return the car to stock defaults>> Might work?
Old Jun 11, 2007 | 08:59 PM
500's Avatar
500
Thanks for the suggestions.
Old Jun 12, 2007 | 07:11 AM
jlturpin's Avatar
jlturpin is infamous around these parts
I get a similar symptom on slow starts as I am letting out the clutch and power is being applied slowly. I only happens from time to time and normally clears up immediately after the first hessitation.
Old Jun 12, 2007 | 05:38 PM
schicago's Avatar
schicago is infamous around these parts
try dry gas product it might be moisture.
Old Jun 12, 2007 | 05:40 PM
Byronmaui's Avatar
Byronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to behold
Hopefully no one pissed in your gas tank.
Aloha
Byron
Old Jun 12, 2007 | 05:42 PM
500's Avatar
500
Aloha
Byron
They'd have to have one tiny little weiner to fit past the flapper
Old Jun 12, 2007 | 05:44 PM
Byronmaui's Avatar
Old Jun 12, 2007 | 10:45 PM
mishref's Avatar
mishref is infamous around these parts
A word of advice if you decide to go this route, after you plug the battery back in and start the car .. you will have several failed messages on the screen (no-psm no-pasm). Don't freak out .. just drive it for a couple miles and it will fix itself back up.
Old Jun 12, 2007 | 10:46 PM
mishref's Avatar
Ever since the weather became humid here, my car has been idling really low at startup (almost going to die) .. I guess the cars might have an issue with moisture.
Old Jun 13, 2007 | 09:53 PM
kauai_diver's Avatar
kauai_diver is infamous around these parts
Happened once or twice about 3 months after I bought it and hasn't happened again, knock on wood. I think the engine management software is adapting to the way you drive, seems to only happen on fairly new cars.
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
NIKAS
Aug 20, 2019 07:53 PM
manfred@loma_wheels
Sep 2, 2015 11:45 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
