ACR runs a 7.22 at the Ring!
Old Aug 28, 2008 | 09:17 AM
HotRodGuy's Avatar
Originally Posted by alzilla300
That's awesome! I can't wait to hear what GM will have to say about this... Seems the Viper is really going out with a bang!
They'll most likely finally put a real drive in the ZR1 instead of an engineer
Old Aug 28, 2008 | 09:18 AM
HotRodGuy's Avatar
Originally Posted by Cornfed
I want an ACR bad but I must say GM did a great job as the zr1 is more user friendly.
completely different vehicles
Old Aug 28, 2008 | 09:21 AM
Sooco100pf's Avatar
Sooco100pf is infamous around these parts
Very Impressive lap time
Old Aug 28, 2008 | 09:42 AM
Milan's Avatar
Milan is infamous around these partsMilan is infamous around these parts
Vipers are cool.
But I guarantee you the average person will be able to drive a ZR1 significantly faster than the Viper.
Old Aug 28, 2008 | 09:46 AM
josh2448's Avatar
josh2448 is infamous around these parts
Like I said on another Forum this morning:
engineers stiffen the front dampers for both compression and rebound (up three clicks to position 11, out of 14 total) and the rear dampers for compression (again, up three clicks to 11). The adjustable rear wing, which offers seven hole positions with the seventh offering the most down force, remains in position three, while the front splitter stays at its initial setting (0) as does the ride height (0.5 inch lower than stock).
evidence that the suspension alterations, along with fresh Michelin Pilot Sport Cup tires, are cutting time
fitted with the Hard Core package, a no-cost option that cuts 40 pounds off the curb weight. About 10 percent of ACR customers order the HCP, which deletes the audio system, trunk carpet, rear cabin sound insulation, tire inflator kit, hood insulator, and steel battery cover
I like this car but is it really a "stock" road car. It is a car that is purchased that is already race ready and not nearly as liveable as the vette IMO. Lets take the same parts off the vette and see what happens. Also, I thought the HCP deleted the A/C, I guess it doesn't though.
Old Aug 28, 2008 | 10:14 AM
rocman's Avatar
rocman is infamous around these parts
He did do a good job though.
rocman's Avatar
Originally Posted by Milan
Vipers are cool.
Absolutely. The ACR has no nannies, and the ZR1 is full of them.
Old Aug 28, 2008 | 11:17 AM
SINISTR's Avatar
SINISTR has a spectacular aura aboutSINISTR has a spectacular aura aboutSINISTR has a spectacular aura about
Originally Posted by rocman
Impressive, if it only was on
"normal" street tires it might hold even more credibility.
Old Aug 28, 2008 | 11:20 AM
SINISTR's Avatar
I'm waiting for that to happen. A pro can most likey knock off a few seconds. The lap wasn't exactly perfect either.
Old Aug 28, 2008 | 12:08 PM
KINGS POWER's Avatar
KINGS POWER is infamous around these partsKINGS POWER is infamous around these parts
Originally Posted by LUISGT3
That car and driver have a 7:20 in it. He missed a couple of shifts, but he was driving the **** out of it. Veeeeeery nice!
Exactly, he made a few small mistakes, but also something interesting, is that based on speed and gear ratio from corner to corner, he really had very few options other than what he was doing banging the car off the rev limiter, becuase if he had to shift to a higher gear, then almost immediately downshift again, this in my opinion would have wasted more precious milliseconds, I personally think he did the right thing, maybe they should think about moving the rev limit up a bit to help.
Old Aug 28, 2008 | 12:20 PM
roncfpz's Avatar
roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !
Damn impressive. Love that car.
Old Aug 28, 2008 | 01:10 PM
Dr J's Avatar
Dr J is infamous around these parts
+1
Probably also the driver is used to race car engines that have much higher redlines.
Old Aug 28, 2008 | 02:01 PM
crush's Avatar
crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !crush Is a GOD !
remarkable
Old Aug 28, 2008 | 02:27 PM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Thats really impressive.
Old Aug 28, 2008 | 02:42 PM
KAA's Avatar
KAA
KAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant futureKAA has a brilliant future
Originally Posted by porschefan1013
I don't think any "bubbles will be bursting"....try using an ACR on a daily basis and see how much you give a **** about its Nurburgring lap time. The car's basically a full on race car that you can use on the street, should you be crazy enough.
I am and I would be.
It's an awesome car and I love to see not one but two American cars at the top of the Nurburgring lap time list, but comparing it to any available Corvette is pointless and just plain silly.
You're right, there is NO comparison.
