Factory Alarm locking problem ...
Old Dec 30, 2010 | 12:15 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Did Search ...
Old Dec 30, 2010 | 02:58 PM
Allen121's Avatar
Allen121 is infamous around these parts
The link took me to a thread about motor oil. Can you repost? I have the same problem. I also notice that my key fob doesn't have very good range and sometimes I need to press the button several times or be very close to the car.
Old Dec 30, 2010 | 03:40 PM
Allen121's Avatar
Thanks! So basically it's a known problem and I'll have to go to the dealer and have them fix it?
Old Dec 30, 2010 | 03:43 PM
astondude's Avatar
astondude is infamous around these parts
I had a similar problem of having to press the FOB many time or get close to the car to unlock. The dealer just gave me a new FOB under warranty. Looking back, I should have replaced the battery first.
Old Dec 30, 2010 | 04:00 PM
acabrera's Avatar
acabrera is infamous around these parts
I had a similar issue with my '06 Vantage as far as remote locking range. Even after replacing the battery, it just would not lock unless I was close to the car. It seems to be better with the DBS but still not great.
Old Dec 30, 2010 | 04:14 PM
Allen121's Avatar
Originally Posted by 007 Vantage
It appears so. I may try lubricating the latch a bit with silicone lubricant, many times that will cure any door latch issues. I feel like when I close the door more forcefully and hold the lock button a bit more firmly for a full second, it helps (although that could be purely psychological).
I found that by either clicking the lock button twice or holding it down longer that it locks the passenger door. But I still find myself having to check it each time which is an inconvenience.
Old Dec 31, 2010 | 05:51 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Locked, but not really
My dealership technician diagnosed the same lock issue on my car as described by 007 in his original post, above. Using his AM computer he determined multiple fault codes had been trigered by a module in the driver's door. Replacement took less than an hour.
Old Apr 28, 2011 | 10:31 AM
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
I've had intermittent problems with this, to the point where I couldn't even lock my door using the key in the door. When I would push lock on the fob it would lock and then unlock...I could do this repeatedly and it would never stay locked. Then I would use the key in the door and it still would unlock for several tries before finally locking. But I think I finally have it fixed.
I changed the settings to turn on light flash with door lock and turned off the automatic door locking when you drive away.
Since then, no problems...the car locks first try with the key fob. I wonder if the light flashing stops whatever short in the circuit that was causing it to unlock. I don't know, but it's nice to have it working properly.
Jul 29, 2019 11:13 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
