Next gen v8 vantage
Old Feb 11, 2011 | 02:00 PM
crackberry005's Avatar
crackberry005 is infamous around these parts
Next gen v8 vantage
hey guys,
ill be in the market for a new car around the end of this year or around 2012. i was wondering does any one know about the next gen v8 vantage? i dont want to buy a v8 vantage only to have new ones come out in year. thanks in advance.
Old Feb 11, 2011 | 02:28 PM
djantlive's Avatar
i dont think there is one on the horizon. db9 would be next before amv8 and that's not in the picture yet.
Old Feb 12, 2011 | 09:52 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Well, you could buy the new Vantage S and tell us all your impressions, including the new 7 speed transmission (especially reverse )...
Old Feb 14, 2011 | 01:33 AM
zambono's Avatar
zambono has a spectacular aura aboutzambono has a spectacular aura aboutzambono has a spectacular aura about
if there is a new vantage it won't look to different than the current one, just like the current one doesn't look very different than the astons of yesteryear
Old Apr 26, 2012 | 01:26 AM
irvineboy's Avatar
irvineboy is infamous around these parts
Rumor has it is 2014 but probably just a minor refresh with more hp and better mileage.
Old Apr 26, 2012 | 06:54 AM
Dr. G's Avatar
Dr. G has a spectacular aura aboutDr. G has a spectacular aura about
DonL - what about reverse? The only reason I ask is because it seems that unless I have it in sport mode it seems to slip the clutch a fair amount.
Old Apr 26, 2012 | 07:32 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
No issue in mine
In fact the opposite - if I pull away in Sport mode the clutch smells
It's a lot better than ASM1 though
Old Apr 26, 2012 | 07:46 AM
DonL's Avatar
The reverse gear ratio in the 6 MT is nearly as "tall" as second gear; it's easy to stall in reverse if you don't slip the clutch, and very difficult to back up an incline.
I was hoping that AM "fixed" that issue in the "S" with the new 7 speed.
Old Apr 26, 2012 | 08:27 AM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
AM just did a re-fresh (so-to-speak) on the V8 Vantage.
Old Apr 26, 2012 | 08:28 AM
AXARUNNER's Avatar
Originally Posted by mikey k
No issue in mine
Clutches don't smell, they can stink though. Noses smell.
Old Apr 26, 2012 | 09:21 AM
mdc's Avatar
mdc
mdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond repute
We can pretty much guess what the next vantage will look like base on what they do the the next gen DB9. I am sure it will be an evolutionary design direction.
Old Apr 26, 2012 | 04:16 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
I have no idea why Aston put such a tall gear in reverse. I wish they swapped out reverse for 1st gear and vice versa. A much taller first would have been alot better with a shorter reverse gear. Sometimes I wonder if they accidentally switched the two
Old Apr 26, 2012 | 04:21 PM
karlfranz's Avatar
Would be pretty jolting to put the car in 1st gear, smash the throttle and have the car go full speed in reverse and then shift into second gear and have it come to a dead stop and start moving in the forward direction.
Old Apr 26, 2012 | 05:11 PM
MichaelD's Avatar
MichaelD is infamous around these parts
Id heard they chose all the forward ratios, then found there was only space in the box for a small, therefore tall, reverse.
Don't know how true that is, but sounds plausible.
They have fixed the problem with the 7-speed box in the Vantage S. There they found room for 7 forward gears, plus a sensible reverse, and saved 30Kg weight. Perfect!
Old Apr 28, 2012 | 12:25 AM
mikey k's Avatar
ASM1 and the manual are the same gearbox
ASM2 is 7 speed with reverse closer to first and no creep mode
Much much better than my ASM1 car.
