Interior lighting
Old Jul 13, 2011 | 02:07 AM
rynacd's Avatar
rynacd is infamous around these parts
Interior lighting
I've seen several posts discussing the lack of interior lighting in the vehicle. What are some solutions members have done?
Led lights? What's the bulb size?
Old Jul 13, 2011 | 06:01 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Do a search. There are at least two detailed threads about installing LEDs.
Old Jul 13, 2011 | 06:19 AM
BLAM's Avatar
BLAM is infamous around these parts
Old Jul 13, 2011 | 11:03 AM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
FYI - it has been about 4 years since I replaced my original bulbs w/ the new ones in the thread ... still no issues.
Old Jul 13, 2011 | 11:33 AM
ptaylor_9849's Avatar
ptaylor_9849 is infamous around these parts
I just did this upgrade and it worked awesome. All 4 interior bulbs can be replaced in under 10 minutes. You do not have to dismantle the overhead map light assembly like once thought. Just use a thin blade screwdriver and pry downward gently just under the plastic ring and the housings will pop out. The footwell lights simply twist out of the housing and can then be pulled out easily. I chose lights that match the instrument panel near perfectly. It only costs like $25 bucks shipped. Here's the part number I used.
Superbrightleds.com.
WLED-CW6
The CW stands for cool white.
Old Jul 13, 2011 | 08:13 PM
karlfranz's Avatar
LEDs are pretty much on or off. I suspect that the nice fade-out of the original map and footwell bulbs as they go off is lost once you switch LEDs?
Old Jul 14, 2011 | 07:41 AM
rynacd's Avatar
thx for the info everyone!
Old Jul 14, 2011 | 08:21 AM
No, my LEDs fade just like org bulbs ...
Old Jul 14, 2011 | 11:24 AM
LED's fade out slowly just like factory bulbs but they are much better IMO.
Old Jul 15, 2011 | 07:25 AM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
Not true. There are many variable intensity LED tactical flashlights out there too. I have one made by Nitecore that has a ring to adjust brightness continuously from off to 285 lumens.
Old Jul 17, 2011 | 08:16 PM
irvineboy's Avatar
irvineboy is infamous around these parts
What are the bulbs for the license plate lights?
COBB Tuning
Jan 1, 2025 09:02 AM
J9277655
Dec 28, 2015 11:01 PM
007AMV8
Oct 19, 2015 09:55 PM
GSR Autosport
Aug 26, 2015 05:20 PM
