My new white toy :)
Old Feb 11, 2014 | 04:59 AM
  #181
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
Received today my seat full carbon (~ 3kg)
Just need to find a solution for mounting.
Old Feb 11, 2014 | 06:36 AM
  #182
telum01's Avatar
Woah, that's some serious weight loss...
What kind of mounting holes does it have? On the side or on the bottom?
Got any shots of the seat from other angles?
Old Feb 11, 2014 | 11:40 AM
  #183
sunir's Avatar
^^^ Rich bud you need a set of these for your Vantage...will make a huge difference next time your on the track!
Old Feb 18, 2014 | 02:23 AM
  #184
vince_1972's Avatar
Thank you for your comments!
In fact, I ordered two different seats to choose which ones I want a "Statüs" and a "Tecnocraft"
For the weight:
- the OEM seat: 27 kg
- the new (complet): 7,5 kg
Here, the seat is made after a lot of testing, it's perfect now!
I create myself the console to adjust the seat support. I can give details if someone wants to buy the same seat.
Comfort is fabulous and is held in the seat.
Little quick pics:
ID:	335342   Click image for larger version
Old Feb 18, 2014 | 11:16 AM
  #185
sunir's Avatar
^^^ look great for racing but may be uncomfortable for regular street usage...
Old Feb 18, 2014 | 11:26 AM
  #186
vince_1972's Avatar
I know it to look weird, but it's more comfortable than original!
Even my wife agrees. The shape is very ergonomic, the buttocks and back, it's just awesome!
Old Feb 18, 2014 | 11:28 AM
  #187
telum01's Avatar
Aside from the thin padding, that doesn't look too bad. It isn't nearly as restrictive as other seats. I had a Recaro Pole Position in my STi and that had good padding but massive bolsters on bottom to keep your legs in place. I fit fine, but it was pretty snug.
Old Feb 20, 2014 | 04:03 AM
  #188
vince_1972's Avatar
Anyone know how to remove the error message of the airbag seat on the display? it becomes urgent.
Thank you!
Old Feb 20, 2014 | 08:33 AM
  #189
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Thank you!
You might need a dealer to remove that code, most scan tools will do drivetrain codes but not chassis codes. If you changed the seat and the sensor isn't picking up a signal correctly it will just come back though.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Feb 20, 2014 | 10:49 AM
  #190
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
Try connecting the sensor terminals together to fool the ECU that a connection with the airbag exists?
Old Feb 20, 2014 | 11:33 AM
  #191
karlfranz's Avatar
This won't work because there would be zero resistance which the airbag circuit would interpret as a short and trigger a fault. When I have disabled airbag systems before, I have hooked up a potentiometer to the two airbag terminals and rotated the pot until the airbag warning went off. I then measured the resistance value of the pot at this point and connected a resistor of equivalent value to the terminals. On the Esprit, the steering wheel airbag turned out to be a really small resistance value of 2.2 Ohms.
On some newer systems, however, this approach may not work because the airbag warning may not change dynamically as you sweep through different resistance values.
Old Feb 20, 2014 | 12:57 PM
  #192
vince_1972's Avatar
Thank you for your answers
My agent Aston Martin told me he could not remove the default code.
Aibag all work together and I'm afraid that removing the fuse will not be enough ...
Pehaps, the small resistance is the solution! Any experience?
Old Feb 21, 2014 | 05:44 AM
  #193
Vergis's Avatar
Could you connect a mini airbag behind the seat to satisfy the ECU?
Eurocharged removed my Emissions warning light so maybe the same can be done for airbags? They have specialist ECU knowledge from my experience with them.
Old Feb 21, 2014 | 08:23 AM
  #194
Removing an emissions light is relatively simple to do, and can be accessed with most tuning tools, which access the drivetrain side. The Airbag light is considered a 'chassis' code, which is not sometime many tuning hardware/firmware developers have access to.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Feb 23, 2014 | 11:18 AM
  #195
vince_1972's Avatar
Exactely!
