What engine oil is better for v8v
My AM dealer uses Mobil 1 but I can't remember which grade 10W40 or 0W40. I think Mobil 1 is fine although I heard Amsoil is better. For everyday driving, Mobil 1 or Castrol synthetic should be fine. It won't make much difference. I think V8 takes 12 quarts.
If I recall correctly, I believe that was for gearbox oil.
I thought he did both the gearbox and motor oil but maybe i'm wrong.
I don't believe Royal Purple nor AMsoil make the correct weight required.
Aston recommends for the V8V: Mobil 1 Extended Life 10W-60, Castrol Edge Sport 10W-60 or
Castrol Formula RS 10W-60
If those are not available, they suggest: Fully Synthetic
5W-50 or 10W-60 oil to specification ACEA A3/B3
Where do you see that Mobil 1 approved? My owners manual specifically states Castrol Edge Sport or Castrol Formula RS.
here's where he did a writeup on the tranny and motor oil.
https://www.6speedonline.com/forums/...installed.html
I am a tech, those are the new Recommended, and Suggested fluid types if Recommened is not available..There was a notice sent to dealers June 2011 of all fluids for 2005+ models...
Awesome! Good to know. Thanks for the info!
