V8V Brakes/Rotors Question
Old Apr 16, 2012 | 03:17 PM
RossL's Avatar
RossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond repute
I just wrapped up a track day and after running about 70 laps the brakes started to sound rough when braking at speeds above 50-60mph. The brakes react fine but sound horrible. I took the car today to a local shop I don't know and they first said the pads/rotors are fine. After explaining in more details they are now telling me all 4 rotors and pads are shot and need replacing. Needless to say it seems sketchy.
My question for the folks here; Could the rotors really be shot after only 70 laps? I followed all the basic rules regarding cooldown, no emergency brake, etc. The brakes work fine but sound problematic. Can these rotors be turned? The mechanic is saying they can't.
2nd question; Any recommendation on a new set? I'm not looking to spend a fortune since I most likely will be selling the car in a year or so.
Old Apr 16, 2012 | 03:28 PM
MichaelD's Avatar
MichaelD is infamous around these parts
How many miles had the car covered before you went on track?
Old Apr 16, 2012 | 03:37 PM
RossL's Avatar
Roughly 10,000 on the clock.
Old Apr 16, 2012 | 04:23 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
This topic has been covered extensively. You can use the search function. Also, see below:
https://www.6speedonline.com/forums/...olution-2.html
I wrecked my first set of OEM rotors after one track day. Without seeing yours, I wouldn't want to say, but yes, it is possible that they are shot on the front! I doubt the rears are done in, though, unless you were really going nuts...
The front brakes need better cooling, plain and simple. You can fool around with 2 piece rotors and big brake kits, but IMO those are all avoiding the real issue.
Old Apr 16, 2012 | 04:40 PM
RossL's Avatar
Thanks spinecho for the search reference. I used it and found little info on longevity overall. I am more concerned with the local mechanic saying everything is fine to you need rotors and brakes on all 4s. I feel the guy is trying to make a few bucks. Unfortunately I won't get to the other shop for another week.
Also, can these rotors be turned? I've done this in the past with other cars but the mechanic said these "these type of rotors can't be turned"
Old Apr 16, 2012 | 04:51 PM
RossL's Avatar
Forgot to mention. I just had the car in for service 2 weeks ago and everything checked out fine. Since then I've put the 70ish laps of track time and about a 1,000 mile drive from MD to SC and back.
Old Apr 16, 2012 | 05:02 PM
spinecho's Avatar
Not sure what would prevent turning. AMFixer or Irish07 would be better able to answer that.
Longevity of the rotors is pretty good with street driving. The issue with track use is uneven pad deposition and surface damage (pitting, scoring), rather than a diffuse loss of metal. IME, this can occur pretty rapidly if you get things hot enough.
Do you have another mechanic or dealer that you trust (or at least can get a second opinion from)? Does your current mechanic have a vested interest in telling you the rotors are shot? Obviously labour charges, but does he sell the parts, too?
Old Apr 16, 2012 | 05:43 PM
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
I'm sure Irish will chime in here but I know that he's told me in the past that there is not a lot of room on the rotors for turning beyond which you get minimal return on investment. Given your plan to sell next year, I'd get a second opinion and then, if necessary, get some OEM rotors and non OEM pads as cheaply as possible (buy from a UK dealer for the former (cheaper), consider Carbtec 1521 or Porterfield R4-S for the latter, both cheaper and better than OEMs by all accounts).
Old Apr 16, 2012 | 06:09 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
The life of rotors is about two pad sets. We do not turn rotors, only replace.
I would ask for the thickness of the rotors. I never suggest rotors unless they are very, very close to min spec or visable damage. There is a min spec of 30mm in the front and 26mm in rear.
I have seen car's where there are heat cracks or spots in them. I very rarely seen the rotors cause noise. Almost always its the pads. Check for cracks or heat spots on the pads as well. Caution using aftermarket pads, as these also can cause noise.
Old Apr 16, 2012 | 06:23 PM
RossL's Avatar
Thanks AMFixer, I'll get more info tomorrow!
Old Apr 16, 2012 | 08:30 PM
Norman75's Avatar
Norman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really nice
I'm second owner on my car so I can't tell how it was used before I bought it but on my last yearly service about 2 months ago they told me I had only 30% left on brakes. They advised changing rotors and pads. My car has only 5,400 miles..
Old Apr 16, 2012 | 08:45 PM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
How is that even possible?
Old Apr 16, 2012 | 10:08 PM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
I had to change pads and rotors at 17000 miles.
Pads I believed, but it seemed quick for rotors. But I was told that replacing rotors at that point is normal. Don't know if its true.
Old Apr 17, 2012 | 01:05 AM
AMFixer's Avatar
I have seen rotors go early with hard drivers. Just depends on the conditions.
Old Apr 17, 2012 | 07:18 AM
RossL's Avatar
Just heard back from the mechanic and they said that the brake pads were orange on the front and back which caused scoring on the surface of the rotors. While there is still material left on both they are recommending replacing everything front and back. Seem right?
