Are the Vantage S/Vantage 12.25 brake pads the same as '12 and older V8V?
Old Jan 19, 2013 | 10:03 PM
timwhayden's Avatar
timwhayden is infamous around these parts
I know the calipers and rotors changed but did the pads? I am considering aftermarket pads and need to know if they will fit. Thanks.
Old Jan 20, 2013 | 12:15 AM
karlfranz's Avatar
No. The V8VS and newer Vantages have 6 piston calipers so the pads are larger.
Old Jan 20, 2013 | 06:22 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
They do (anyone found the real supplier part no for Pagid/Brembo?)
The rears remain unchanged
Old Jan 20, 2013 | 07:01 AM
RossL's Avatar
RossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond repute
Fronts are bigger
Old Jan 20, 2013 | 07:15 PM
timwhayden's Avatar
Thanks for the replies. Any aftermarket pads available yet for the larger brakes yet like Carbotech or porterfield?
Old Jan 20, 2013 | 09:26 PM
karlfranz's Avatar
^^^^Even if none already exists, Porterfield can create a set for you. They need a trace template of the pad in 1:1 scale and the pad thickness specifications for the Aston application. I did this about 15 years ago for my Esprit which has factory Brembo brakes. The good thing is that it only needs to be done once by one individual. Once they match up the template to an existing on from their inventory or create a new one, it will always be available for everyone else.
Old Jan 22, 2013 | 12:17 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Carbotech can create a custom set for you no problem, that's what I did when I had the first Aston sets ever made. If you want a great dustless zero noise street pad for the Aston I HIGHLY recommend their 1521 pad compound. It's the best street pad IMO.
Old Jan 22, 2013 | 04:19 AM
mikey k's Avatar
That's good to know Porterfield and Carbotech will "play ball" on these.
I've got just under 10k miles on my S now so may well need some fronts soon.
Old Jan 23, 2013 | 02:58 PM
Fubar's Avatar
Fubar has a spectacular aura aboutFubar has a spectacular aura about
I have been exchanging emails with Brenda at EBC brakes. She is getting the deminsion s from Aston Martin and is trying to get me a part number that will fit the '12 Vantage S. I will post up here when I get a solid answer from her.
Old Jan 24, 2013 | 09:45 PM
The only rotors you cannot use Carbotech on are Racingzbrake rotors, but those aren't even made for Aston so thasts a non-issue. On brembos they were fantastic once broken in. Excellent cold bite, no dust, zero noise whatsoever. I still need to have them make a set of EBRAKE pads for our cars, once I get my next Aston here in the next month or so I will add that to the list.
takenotes996tt
Jan 20, 2016 06:34 AM
Rockinc1
Sep 30, 2015 06:44 PM
manipou
Sep 2, 2015 12:42 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
