How do I disable Crawl function?
Old Feb 9, 2013 | 12:40 PM
Carmonkey's Avatar
Carmonkey is infamous around these parts
Hi All,
I love my 09 V8V, but the crawl feature is driving me crazy. Is there any way to turn that off? Or can it at least be adjusted to a lower speed? 5 mph is way to fast for backing out of my garage, and too fast for parking structures as well.
I would prefer to turn it off altogether. My Maserati Gransport has the same tranny but no Crawl feature and I love it! I like cars to move only when I press on the gas, that's not too much to ask, is it?
Thanks -- Andy
Old Feb 9, 2013 | 03:37 PM
Irish07@VelocityAP's Avatar
From the factory it cannot be disabled, the new 7-speed v8v's no longer have the crawl feature...maybe an aftermarket program could be tweaked, might want to check with Stuart at RSC
Old Feb 10, 2013 | 10:07 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Not come across any one disabling it
Old Feb 10, 2013 | 05:40 PM
Carmonkey's Avatar
Thanks, I'll check with him, hopefully there is an easy way to disable it in software, or at least adjust the max speed to 1 or 2 mph.
Old Feb 10, 2013 | 05:41 PM
Carmonkey's Avatar
But you want to, you know you do!
Old Feb 11, 2013 | 04:22 AM
mikey k's Avatar
Absolutely awful feature
I found a solution though if a little expensive
French Loop 746_resize by mikey k V8VR, on Flickr
Old Feb 11, 2013 | 09:55 AM
fbiguy's Avatar
fbiguy is infamous around these parts
I also went the route Mikey took. It's a much more intuitive setup, if a bit pricey. Good luck finding a solution for the 6 speeds, it would be very worth it.
Old Feb 11, 2013 | 11:05 AM
You wouldn't be able to lower the crawl speed..otherwise you would be slipping the clutch constantly to reduce the crawl speed..and with that tall reverse gear..heheh good luck.
I'm sure it can be disabled completely via a tune, there's no difference in the transmission control module itself for a 7-speed or 6-speed..it's all software
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Feb 11, 2013 | 02:36 PM
Carmonkey's Avatar
@Mikey and fbiguy - Thanks, way to rub it in! I like the way you're thinking, but my checkbook told me no, no, no! So I must keep looking for a better answer...
Old Feb 12, 2013 | 04:06 AM
mikey k's Avatar
Goodluck as Irish says it needs the box ECU cracking to disable it completely, he has a VERY good point on the speed adjustment you will ruin the clutch. I've not come across anyone cracking it so far.
Save some cents up and get a used S it is FAR great than the sum of the changes
Old Feb 13, 2013 | 06:01 PM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
I don't know, I don't seem to have a problem with it. Most of the time I don't let it engage and when I'm going in or backing out of the garage I just don't let it go too fast.
Old Feb 14, 2013 | 02:02 AM
mikey k's Avatar
That's the trick
Either enough throttle to stop it kicking in or let it do its thing - don't fight it
Old Feb 14, 2013 | 04:09 PM
Carmonkey's Avatar
Well, after a quick discussion with the service tech at my dealer, there is a pretty easy way to disable it for short periods (like when I go in and out of my garage). Simple trick?
Pull the hand brake up just one click. That disables "crawl mode".
Works great! Now I can ease in and out of tight spaces without worrying that the minute I let up on the gas the car will speed up.
Just so you know why this is a big deal for me, my garage is extremely tight and requires me to begin to turn immediately as I back out to clear the house, but not too much or I'll scrape the other car. It's a pain, but the house is 100 years old and not ideally suited for cars.
Fun fact: the service tech told me that at least one V8V owner drives all the time with the handbrake up one click to disable crawl. I'm not going to go that far.
Old Feb 15, 2013 | 01:38 AM
mikey k's Avatar
Now that is interesting
Old Feb 15, 2013 | 09:00 AM
Carmonkey's Avatar
Hey Mikey! I followed the link to your Flickr photos. Your photos are great, you've had some nice trips in your Vantage!
