Hi i have a problem with my AC
Old Apr 1, 2013 | 09:02 AM
has-Db9's Avatar
has-Db9 is infamous around these parts
My car is db9 2005 Switch on my ac And I drive my car for one hour it's getting Hot i dont know why
Old Apr 2, 2013 | 06:05 PM
hph's Avatar
hph
hph is infamous around these parts
I had similar problem with my 05 DB9. It turns out one of the lines from the compressor had a hole and everything leaked away. Apparently it is a common issue on these cars. Luckily mine was under warranty so it was replaced under warranty. I was told it'll cost about $2k if I have to pay for it. I've also read somewhere about just welding the hole??? I may be wrong.
Old Apr 2, 2013 | 06:31 PM
telum01's Avatar
if there's a hole in the line, there's no way you should have to pay $2k. that's absurd!! if that's really the case, just weld the hole and recharge the system. very cheap to do.
Old Apr 2, 2013 | 10:48 PM
has-Db9's Avatar
Thanks alote
Old Apr 3, 2013 | 03:16 PM
has-Db9's Avatar
Okay I know that the AC if you are driving hard to disconnect That is anyway to make it not disconnect Because I live In the middle east and I need to drive fast
Old Apr 3, 2013 | 06:06 PM
telum01's Avatar
can you rephrase that? not quite sure what you meant.
say it in Arabic if that helps.
Old Apr 4, 2013 | 11:01 AM
has-Db9's Avatar
What i mean is when i drive my car for 1 hour the AC in the driver side get warm , if i accelerate the AC disconnect , i took it to the dealer and they told me that is normal when you accelerate the AC will disconnect so the engine can reach to a high performance !! Is there any way to make the AC work all the time ?
PV=nRT.
Sep 9, 2022 06:06 PM
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
