V8V All seasons
Old Aug 6, 2013 | 04:37 PM
dmose's Avatar
dmose is infamous around these parts
V8V All seasons
I need new tires ...I don't plan on driving in the winter, March - October/Nov ..maybe the occasional trip in the city/slush.
I'm looking at all seasons, and have been quoted
245/35/19 & 275/35/19 Michelin Pilot Sport A/S
I'm told the fronts are not available in the OEM size of 235/40R19 ...
do you think going 245/35/19 is a bad idea? will the tires protrude too much on the front? will the handling be affected that much?
I don't track / race the car...I'm a city slicker drive 5-10KM a day max always under 140KM / h
Old Aug 6, 2013 | 06:09 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
That's a nice tire, nearly as good as a summer performance tire. You will be fine with slightly wider front, won't even notice it.
Old Aug 6, 2013 | 06:47 PM
telum01's Avatar
i have 245/40R19 tires up front on my V8V. the overall diameter is 0.3" taller than the original tires, which is about a 1.1% difference. i have no issues at all.
the A/S 3 in 245/35R19 is 0.6" shorter than the original tires, a 2.3% difference.
i'm not an expert by any means, but it looks like 245/40R19 is closer to spec.
Old Aug 6, 2013 | 07:45 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
The optional "sport pack" tire sizes for the '07 Vantage were 245/40/ZR19 for the fronts and 285/35ZR19 for the rears. Check your owners manual...
I have changed to these sizes, as there are many more "pairs" available from different manufacturers...they fit fine on the standard 19" rims, and there is no appreciable speedometer error, that I can notice. I would not recommend a different pair of tire sizes front to rear...you should be able to find the Michelins in these sizes.
FYI, I currently have a set of Hankook Ventus V12 Evo's mounted as my street tires, and I also have a set of Bridgestone RE-11's for use as my track tires. Both ride extremely well, with little or no noise.
If you do "no" wet driving at all, you may prefer the "extreme performance" Bridgestone summer tire, as it does perform better in the dry than the V12 Evo's. I have no experience with the Michelins you are considering...YMMV
Last edited by DonL; Aug 6, 2013 at 07:48 PM. Reason: Added reference to owners manual
Old Aug 6, 2013 | 08:50 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Continental DWS is a fantastic all season tire that lasts a very long the but still has very good grip.
Old Aug 7, 2013 | 07:32 PM
dmose's Avatar
Cool thanks for the advice!
Old Aug 9, 2013 | 12:43 PM
marioV8V's Avatar
marioV8V is infamous around these parts
I switched my vantage over to the Bridgestone Potenza RE11, they're a great performance tire with tons of grip! and they're pretty good all season as well
Old Oct 5, 2013 | 11:20 AM
dmose's Avatar
So I needed up going with the Michelin Pilot Sport A/S ..could not be happier for an all season, super quiet, wet traction is amazing.
Question...what tire pressure's should I be running? Factory spec or something else? (since the rears are not exactly factory sizes)
235/40R19
rear
275/35R19
Should I still follow 36PSI rear, 33PSI fronts?
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
V565MAN
Oct 2, 2015 05:48 AM
ECS Tuning - VW
Sep 30, 2015 03:11 PM
TOGWT
Detailing
Sep 27, 2015 06:09 AM
