Code P2800
Old Sep 5, 2013 | 06:04 PM
Benjamin09's Avatar
Benjamin09 is infamous around these parts
Code P2800
I'm getting code P2800 off my car. Anyone know what that is? I can't seem to find a OBD code for that.
I have a 2005 DB9
Old Sep 5, 2013 | 07:30 PM
Benjamin09's Avatar
Also, went for a ride in the car after clearing the code to see if it would pop up. Half way back I saw a red light flash on my dash for a brief second. It popped up again when I was looking at it, luckily to see what it was. (maybe not so lucky)
The light was for Low Engine Coolant Level. ON and Off. I think this happened one time before when I was reversing but didn't catch what it said.
Is my car electronically falling apart?? Anybody hear or see anything like this before?
Sigh...
Okay. See that to put distilled water in to top off from previous posts. Feeling a little better.
Old Sep 5, 2013 | 09:05 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
A Google search turns up a generic code of Transmission Range Sensor "B" (PRNDL input)
Old Sep 5, 2013 | 09:51 PM
Benjamin09's Avatar
Thank you kind sir. Google outwits me again.
Old Sep 6, 2013 | 07:31 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
There could be several reasons for P2800. The code is caused by a voltage difference seen on the PRND buttons when there pressed. The slightest voltage difference can set the code. Giving the fact your car is a 05 new buttons and what is called a shift by wire module may be needed. They update the buttons to a three contact type instead of a two contact type. A ECM software update may also be needed. You may also need to check the grounds for the ECM as they may be dirty.
Old Sep 6, 2013 | 08:46 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
If you end up having to get new buttons, look into the newer glass ones
Old Sep 6, 2013 | 10:08 AM
Benjamin09's Avatar
Thanks AMFixer.
Follow up question. Best place to find the buttons? Watch AstonMartinBits.com and other sources?
Old Sep 6, 2013 | 10:16 AM
AMFixer's Avatar
I would just be careful buy used parts. Don't want to get older buttons and still have the same issue. If your good with a multi meter I could tell you what to check to figure out what it is.
Old Nov 17, 2019 | 05:57 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
HI AM fixed
I have P2800 code too, I have been intermittently having issues with buttons not working, i removed them and cleaned them and it worked for a while, but at that time i did not have P2800 code, I also have P1712, P0483 code.
Would greatly appreciate you input. I do have separate post about these codes, you could reply there too.
Thanks.
Old Nov 17, 2019 | 07:18 PM
yvr's Avatar
yvr
AMFixer hasn't been seen here for a few years.
Old Nov 17, 2019 | 07:41 PM
oh boy that's a big loss to the AM community.
I hae not been here often lately, looks like irish07 is with AM velocity now?
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
PelicanParts.com
997 Vendor Classifieds
Oct 5, 2015 01:07 PM
nagual911
Oct 1, 2015 01:52 AM
