Would wheel spacers void the warranty?
Old Jan 22, 2014 | 08:58 PM
timwhayden's Avatar
timwhayden is infamous around these parts
I have a '13 V8V and would like to put rear wheel spacers on. Any warranty issues with suspension etc?
Old Jan 22, 2014 | 09:24 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
Not unless AM can directly correlate a part failure to the installation of an aftermarket part. I don't see how spacers will affect any part of the car other then perhaps a minuscule bit of tire wear.
Old Jan 27, 2014 | 04:00 PM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
Instead of spacers, go with a wider wheel/tire combo. V8 Vantage S wheels and tires do make a big difference in looks and handling and fill out the wheel wells better. IMO
Oh, and having been-there, done that with my old 07 Vantage, its not a simple bolt-on process as one might think. The spacers were relatively cheap, the labor was not.
Old Jan 28, 2014 | 09:32 PM
timwhayden's Avatar
I already have the V8S wheels and tires and love them but would like the rears to fill out the wheel wells a little bit more...
Old Jan 29, 2014 | 05:02 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Warranty loss/Filling wheel openings
Wheel spacers=greater/unique/untested loads on original equipment wheel bearings.
Consider upsizing your rear tires to 40 aspect ratio from 35=no bearing load change, but fuller wheel openings.
Old Jan 29, 2014 | 07:12 AM
MichaelD's Avatar
MichaelD is infamous around these parts
If you get the H&R spacers they can be removed without trace, IF your wheels have the recesses for the studs.
They will generate additional load on the bearings, but that isn't considered a weak point on these cars, so it's extremely unlikely to cause you a problem
Old Jan 29, 2014 | 10:32 AM
AXARUNNER's Avatar
Here is a photo of my old Vantage with S wheels and rear wheel spacers. Its almost too much for the car… The car did handle very well and I posted my fastest ever time with it at Lime Rock Park last year.
Old Jan 29, 2014 | 03:47 PM
MichaelD's Avatar
It's encouraging that you were OK putting it under (fast) track loads without a problem. Road use shouldn't ever get near that loading, well, Ok, only sometimes
Old Jan 30, 2014 | 05:41 AM
flinder's Avatar
Conservative yes/Radical no
"All things in moderation", including wheel spacers.
Follow this self evident truth...you will have no problems.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
