DB9 Front Clunk Noise going over bumps?
Old Mar 4, 2014 | 10:04 PM
4leafcloverz's Avatar
4leafcloverz is infamous around these parts
Hello everyone,
My '05 DB9 has developed a strange clunking noise coming from my front wheel arch area while going over bumps. Has anyone had / fixed this before? Very interested in your experiences. Thanks!
Old Mar 5, 2014 | 04:31 AM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
My porsche had this a while back. Worn bush. This happens with age of car.
Old Mar 5, 2014 | 02:51 PM
Irish07@VelocityAP's Avatar
Car is getting old, being your in BC sure you store it for the winter, so a lot of stationary periods of no movement( she starts to sag! ...I've done it all from all rack parts, upper/lower arms, bushings on sway bar, links, dampers, engine mounts....even spacers for airbag module.
Is the noise from the front most floor area, or centered heard travelling up the steering wheel..if it's in the floor area can't really help, but if in the steering it's most commonly related to the airbag not having spacers on the bolts for early models (pre 09MY)..
Say your not sure o9f the location..try this, drive on a straight bumpy road you hear the noise of concern, hold the drivers airbag as if your were trying to avoid it from moving up/down..does the noise go away? If it does..airbag spacers for bolts are needed(5$ fix)..if not..dealer or indie shop visit would be required.
Noises like this would have to be diagnosed in mainly person with chassis ears..sry I can't be of more help than this..
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Mar 5, 2014 | 06:07 PM
sunir's Avatar
On left to right uneven surfaces could mean worn bushes or sticking control arm joints or tie rod ends from long periods of sitting.
Old Mar 5, 2014 | 08:27 PM
Not at all, I will try to isolate the noise further when I get a chance. Thank you for the help!
Old Mar 6, 2014 | 03:51 AM
My friend in Seattle had the same problem a while back and said the noises coming from my car were the same in his. The dealer told him it was a strut mount problem and the repair was about $6k in parts and$2k in labor.
As for the noises, they are coming from where my feet are (and I can feel a little vibration as well). Do you think there is a more economical way to remedy this problem? Maybe I could have the bushings checked first? Thanks again
Old Mar 6, 2014 | 10:33 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
Upper control arm bushings?
tzeseong
Aug 17, 2024 11:08 AM
DonBond
Apr 16, 2016 07:55 PM
Enemy
Nov 10, 2015 08:01 AM
New991S
Aug 31, 2015 05:22 PM
Zero911
Aug 24, 2015 06:51 PM
