Wiper Upgrade for 2007 Vantage
Old Jun 13, 2014 | 01:01 AM
Jeremyosj's Avatar
Jeremyosj is infamous around these parts
The metal frame wipers on the Vantage rather ugly. I found the Bosch AeroTwin wipers to be a direct fit!
ID:	386927   Click image for larger version
ID:	386928   Click image for larger version
Old Jun 13, 2014 | 04:14 AM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
do you have a part number?
Old Jun 13, 2014 | 09:38 AM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
Bosch Aerotwin AR801S work perfect on mine 09MY
Cheers
Christian
Old Jun 13, 2014 | 10:27 AM
zvez's Avatar
thanks Christian!
Cheers
Christian
Old Jun 13, 2014 | 10:51 AM
dmose's Avatar
dmose is infamous around these parts
Where can you buy these in North America? everything turns up europe..
Old Jun 13, 2014 | 12:52 PM
Ellipsis's Avatar
Ellipsis is infamous around these parts
Looks good! I bought the Bosch Icon series at Pep boys... However they look exactly the same as yours. I'm not sure what's different about the Aerotwin vs Icon.
Either way AM of LI didn't like them and told me they wouldn't work at 150mph
Old Jun 14, 2014 | 08:45 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Why won't they work at 150mph? If anything the look more aero dynamic.
Once mine go out I will definitely upgrade with these! Thx for tip
Old Jun 14, 2014 | 08:58 AM
I cannot seem to find that specific part number anywhere. Does anyone know what actual car the Bosch Aerotwin AR801S is used on? Volvo I assume?
Perhaps an equivalent Icon series blade part number?
Old Jun 14, 2014 | 09:00 AM
karlfranz's Avatar
I can tell you that, on my Esprit, when you pass 130, the "aero" blades actually started to move the wiper arm up the windshield. By the time I'm going 180 it is at the middle of the windshield. Luckily the Esprit only has a single wiper so (due to the direction of its sweep) it sits in the field of view of the passenger instead of the driver. I suspect that the ugly holes in the original design of the Vantage blade let air flow through it rather than create wind resistance. The newer Vantages actually resolved this problem by redesigning the wiper arm as well.
Old Jun 14, 2014 | 09:15 AM
Hey guys,
Did more research, turns out the Aerotwin branding is used for Bosch wipers made in Europe, while the Bosch Icon brand is used specifically for the US aftermarket. They are essentially the same identical thing, just the branding and availability is different.
I also found out the Bosch I con is basically sold by the wiper length with a much simpler part number system.
Passenger wiper = 20"
Drivers wiper = 24"
I still don't know exactly which one to order but that should help at least clarify some of the confusion of why Aerotwins are not available here in the USA
Old Jun 14, 2014 | 11:51 AM
GDay2's Avatar
These work as well
I bought them from amazon.com:
Goodyear GY-WB765-20 (Passanger side)
Goodyear GY-WB765-24 (Driver side)
Fit and work as well as Bosch
Cheers
Christian
Old Jun 16, 2014 | 08:59 AM
Jeremyosj's Avatar
For RHD car
BBA500 Passenger Side
BBA600 Driver Side
http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=7228 7
Old Jun 16, 2014 | 11:45 AM
Hey guys,
After doing more research it appears you can use the Bosche Icon series, but there's re two versions of each blade, A or B. The 24" blade is the drivers side blade (rests in center of windshield, and the 20" is the passenger side that rests on far end of the windshield.
The A designation is for less spring curvature (usually drivers side wiper). The B designation is for more curvature (passenger side). With this in mind it appears the proper combination would be 24A + 20B.
With that said some of the Aston owners on piston heads have tried the Aerotwin but are running into the problem that the stock aston wiper arm spring is too weak to counter act the larger spring force of the wiper design and is causing H&R center of the wiper to not shed water:
http://www.pistonheads.com/Gassing/t...r+Blades&mid=0
Jeremy can you comment on this? Have you tested the wipers in heavy rain yet to verify?
Thanks,
007
Old Jun 16, 2014 | 12:16 PM
karlfranz's Avatar
I've been using the Bosch Icon blade on my Vantage for years without any problems.
Old Jun 16, 2014 | 06:34 PM
zvez's Avatar
Thnks! Jeremy.
Chris
For RHD car
BBA600 Driver Side
