Side turn light bulb cover?
Old Sep 7, 2014 | 08:49 PM
theegolden1's Avatar
theegolden1 is infamous around these parts
This fell off sometime today. What is the exact name so I can order a new one?
Thanks in advance.
Old Sep 7, 2014 | 08:56 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
It's an "Indicator side repeater", and if you have a DB9 or a Vantage it's part number 4G43-13K376-AA. Probably the same part for various VH-platform cars.
http://www.astonmartinbits.com/models/4-DB9/parts/717
Old Sep 7, 2014 | 08:58 PM
Originally Posted by 62Jeff
It's an "Indicator side repeater", and if you have a DB9 it's part number 4G43-13K376-AA
Geez, I wasn't even close to the right name. Lol. Thank you, Jeff.
Old Sep 7, 2014 | 09:02 PM
62Jeff's Avatar
You are welcome.
My understanding is you have to remove the inner fender liner in order to replace it. My dealer charged $213 USD labor to replace mine while I had the car in for my annual service. My invoice specifically lists it as "LAMP" in the Description, along with the part number I cited above.
Old Sep 7, 2014 | 10:22 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Not too hard to replace yourself. Part is about $35.
1.Turn your tire to allow access to the fender liner. You can remove the tire for better access.
2. Remove as many of the fasteners on the exterior of your wheel well fender liner, including the bottom, to allow your hand to reach in. (take a look inside with a flashlight). You might wear a long sleeve shirt as its a tight fit, depending on your arm size.
3. Grasp the plastic fixture from the inside and turn 1/2 turn. Have the new replacement in front of you to insure you rotate the correct way for removal. You should be able to turn it with you fingers, IF NOT be care when using any tool or lubricant inside the fender.
4. Once loose - pull gently out of the round opening. "careful as the single wire is not real long" - disconnect the single wire. If the wire on yours is short you might need to reach your hand inside the fender to disconnect/connect the wire.
5. Then reverse the procedure with the new one. The rubber grommet on the new repeater might be stiff.. put a little liquid soap to allow for the easier 1/2 turn to reassemble. Make the 1/2 turn ON from inside the fender with your fingers to get it fully on. Test the light prior to reassembly. Job should take less than an hour. Good luck!
Old Sep 7, 2014 | 10:29 PM
Wow! Thank you very much for that how-to. I'll be doing this ASAP. But quick question........since the outer cover is missing, can I simply buy the new "repeater" and take the cover off it and pop it on my existing one?
Old Sep 8, 2014 | 08:51 AM
. IF your very lucky ! I have heard of someone being lucky enough to get the white plastic to easily turn and be removed from the outside of the fender. There is not much to hold onto, see pic of grey piece ( with bulb) that's attached to the white cone. I believe you risk damage using tools to attempt to grip it from outside. The white exterior plastic piece can be VERY HARD to twist. Get your new parts first to look at configuration. Take your time, Good luck.
ID:	401261   Click image for larger version
Old Sep 8, 2014 | 09:25 AM
Thanks again, Sportspack!
Old Sep 9, 2014 | 02:18 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
BTW its a Ford part
Old Sep 9, 2014 | 06:52 AM
Originally Posted by mikey k
BTW its a Ford part
But unfortunately, I can't pick this part up at the local Ford auto parts store
Old Sep 11, 2014 | 01:51 PM
mikey k's Avatar
Well you could if I could recall the part number
Old Sep 11, 2014 | 05:32 PM
Aston Martin part # is AST 4G43-13K376-AA- Don't know about Ford ??
Old Sep 11, 2014 | 05:56 PM
karlfranz's Avatar
Just look for a Ford Puma 1.4 side repeater light such as this on eBay:
http://www.ebay.com/itm/FORD-TRANSIT...item20e566b17f
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 20, 2015 05:54 AM
Jeff1smith
Aug 19, 2015 09:41 PM
