DB9 Dipstick
Old Nov 7, 2014 | 12:23 PM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
DB9 Dipstick
Member "yvr" was kind enough to tell me that the part number for the replacement (shorter) DB9 dipstick is # 4G4E-6750-AC. My dipstick is 4G4E-6750-AB. Does that mean it's the original stick? if so, until I can get a replacement, can someone tell me how much shorter the new one is?
Thanks.
Old Nov 7, 2014 | 01:50 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I think the intent was to get an extra litre/quart of oil in there. If that's true, then your "full" level probably indicates that you're a quart down & should add one. Hopefully someone else can answer authoritatively. Call a dealer?
Old Nov 10, 2014 | 07:37 AM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Thanks.
If you try to order 4G4E-6750-AB with the AM Parts system, it only allows you to order 4G4E-6750-AC as a supercession so I believe you still have the earlier dipstick.
Service notes should show if it was replaced also.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Nov 10, 2014 | 11:32 AM
zuman's Avatar
Thanks all. I ordered a replacement (about $40 from a dealer).
Old Jan 12, 2016 | 08:19 AM
ajmevans's Avatar
ajmevans is infamous around these parts
Just as an update, just serviced the car and added the extra oil amount as per the AM Service Bulletin (BTW AM, 11.4 L is not 12.96 US Quarts, its 12.05). I have marked my old did stick and the level is halfway between the max mark and the upper indent on the stick.
Mark showing correct oil level (11.04l) on older dipstick
Old Jan 12, 2016 | 03:03 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
I thought the dip stick update was a recall and was provided for free?
Old Jan 12, 2016 | 05:06 PM
ajmevans's Avatar
Yes, correct it was a recall, but amazing how many pre-08 DB9's did not have it done, (my 05 has been religiously serviced by a top of the line AM dealer every year without fail, yet never had the dip stick changed) you could be running with not enough oil, this is just a home fix for those out there wondering....and also a correction to the AM Service Bulletin that you DO NOT put 13 quarts in you DB9
Old Dec 8, 2016 | 11:52 AM
bluecab's Avatar
bluecab is infamous around these parts
Stuart,
Do you know the date of the original Service Advisory or recall that changed the sticks?
The new, shorter dipsticks started with VIN 10286 which would be mid-year 2008 I think, but I have never found a date for the recall action?
Old Dec 8, 2016 | 12:16 PM
ajmevans's Avatar
Dip Stick Change
FSA 165 V2 was issued in May 2008
Reference FSA 165V2 Issued May 2008 Model All DB9 Vehicles VIN Range A00001 to A10286 Subject Shorter Dipstick for DB9
Type: Service Communications
Old Dec 8, 2016 | 09:30 PM
Timodc's Avatar
5 Year Member
Timodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to behold
This was a Recall but is only performed in conjunction with a service. If you did not purchase a service from a dealership, the recall was never performed.
KOCF
Jul 18, 2019 03:09 AM
airbusdrvr
Dec 27, 2015 07:43 PM
Ekaplan1020
Oct 2, 2015 07:39 AM
Collinsjd
Sep 29, 2015 09:38 AM
